Commit e3c58908 authored by Mikaël Salson's avatar Mikaël Salson
server/Makefile: Rule to install all the prerequisites
parent c8589802
install: install_web2py install_unit_tests
install_web2py: install_web2py:
wget http://web2py.com/examples/static/web2py_src.zip wget http://web2py.com/examples/static/web2py_src.zip
unzip web2py_src.zip unzip web2py_src.zip
...@@ -32,3 +34,5 @@ clean_unit_tests: ...@@ -32,3 +34,5 @@ clean_unit_tests:
rm -f web2py/test-reports/*.xml rm -f web2py/test-reports/*.xml
cleanall: clean_unit_tests cleanall: clean_unit_tests
.PHONY: install install_web2py install_unit_tests unit install_web2py_standalone launch_web2py_localhost launch_fuse_server kill_fuse_server clean_unit_tests cleanall
