GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
e058027b
e058027b
Ryan Herbert
Committed by
Mathieu Giraud
Aug 30, 2017
segmenter.js remove duplicate method introduced by rebase
6be9249a
browser/js/segmenter.js
e058027b
@@ -827,41 +827,6 @@ updateElem: function (list) {
div_elem
appendChild
seq_name
div_elem
appendChild
seq_name
* add a sequence to the segmenter
* build a div with sequence information and sequence
* @param {str} id sequence id
* @param {str} sequence
addSequenceTosegmenter
function
id
locus
str
var
self
this
this
aligned
false
this
sequence
id
new
genSeq
id
locus
this
m
this
this
sequence
id
load
str
var
divParent
document
getElementById
listSeq
var
previous_li
divParent
getElementsByTagName
li
if
previous_li
previous_li
length
this
first_clone
id
var
li
document
createElement
li
li
id
seq
id
li
className
sequence-line
var
spanF
document
createElement
span
spanF
id
f
id
this
div_element
spanF
id
var
spanM
document
createElement
span
spanM
id
m
id
spanM
className
seq-mobil
spanM
innerHTML
this
sequence
id
load
str
toString
this
li
appendChild
spanF
li
appendChild
spanM
divParent
appendChild
li
* get the germline from the germline object
* and use add germline to the segmenter
