Commit df2b6d76 authored by Ryan Herbert's avatar Ryan Herbert
sample_set.py add sample and set info to metadata on export
parent fe209f09
Pipeline #18457 passed with stage
in 40 minutes and 32 seconds
...@@ -289,12 +289,13 @@ def result_files(): ...@@ -289,12 +289,13 @@ def result_files():
q = db( q = db(
(db.sample_set.id.belongs(sample_set_ids)) & (db.sample_set.id.belongs(sample_set_ids)) &
(db.sample_set_membership.sample_set_id == db.sample_set.id) & (db.sample_set_membership.sample_set_id == db.sample_set.id) &
(db.results_file.sequence_file_id == db.sample_set_membership.sequence_file_id) & (db.sequence_file.id == db.sample_set_membership.sequence_file_id) &
(db.results_file.sequence_file_id == db.sequence_file.id) &
(db.results_file.data_file != None) & (db.results_file.data_file != None) &
config_query config_query
results = q.select(db.results_file.ALL, db.sample_set.ALL, db.patient.ALL, db.run.ALL, db.generic.ALL, left=left_join) results = q.select(db.results_file.ALL, db.sequence_file.ALL, db.sample_set.ALL, db.patient.ALL, db.run.ALL, db.generic.ALL, left=left_join)
sample_types = ['patient', 'run', 'generic'] sample_types = ['patient', 'run', 'generic']
mf = ModelFactory() mf = ModelFactory()
...@@ -310,7 +311,9 @@ def result_files(): ...@@ -310,7 +311,9 @@ def result_files():
log.debug("res: " + str(res)) log.debug("res: " + str(res))
metadata.append({'id': res.sample_set.id, metadata.append({'id': res.sample_set.id,
'name': helpers[res.sample_set.sample_type].get_name(res[res.sample_set.sample_type]), 'name': helpers[res.sample_set.sample_type].get_name(res[res.sample_set.sample_type]),
'file': res.results_file.data_file}) 'file': res.results_file.data_file,
'set_info': res[res.sample_set.sample_type].info,
'sample_info': res.sequence_file.info})
path = defs.DIR_RESULTS + res.results_file.data_file path = defs.DIR_RESULTS + res.results_file.data_file
zipfile.writestr(res.results_file.data_file, open(path, 'rb').read()) zipfile.writestr(res.results_file.data_file, open(path, 'rb').read())
