Commit deda88a2 authored by Mathieu Giraud's avatar Mathieu Giraud
doc/vidjil-format.md: converted from doc/format-analysis.org + details
parent 2f952c41
This diff is collapsed.
...@@ -491,7 +491,7 @@ two windows that must be clustered. ...@@ -491,7 +491,7 @@ two windows that must be clustered.
The main output of Vidjil-algo (with the default `-c clones` command) are two following files: The main output of Vidjil-algo (with the default `-c clones` command) are two following files:
- The `.vidjil` file is *the file for the Vidjil web application*. - The `.vidjil` file is *the file for the Vidjil web application*.
The file is in a `.json` format (detailed in [format-analysis.org](format-analysis.org)) The file is in a `.json` format (detailed in [vidjil-format](vidjil-format))
describing the windows and their count, the consensus sequences (`-y`), describing the windows and their count, the consensus sequences (`-y`),
the detailed V(D)J and CDR3 designation (`-z`, see warning below), and possibly the detailed V(D)J and CDR3 designation (`-z`, see warning below), and possibly
the results of the further clustering. the results of the further clustering.
...@@ -10,6 +10,7 @@ repo_name: gitlab ...@@ -10,6 +10,7 @@ repo_name: gitlab
pages: pages:
- vidjil-algo: vidjil-algo.md - vidjil-algo: vidjil-algo.md
- locus and recombinations: locus.md - locus and recombinations: locus.md
- .vidjil file format: vidjil-format.md
extra_css: extra_css:
- mkdocs-extra.css - mkdocs-extra.css
