Commit dd87b250 authored by Mikaël Salson's avatar Mikaël Salson
test_pre_process.rb: Bad ID
Don't know how this could work previously
parent d3e58cc7
...@@ -42,7 +42,7 @@ class TestPreProcess < ServerTest ...@@ -42,7 +42,7 @@ class TestPreProcess < ServerTest
form.text_field(:id => "pre_process_name").set('dummy') form.text_field(:id => "pre_process_name").set('dummy')
form.textarea(:id => "pre_process_command").set('dummy &file1& &file2& > &result&') form.textarea(:id => "pre_process_command").set('dummy &file1& &file2& > &result&')
form.textarea(:id => "pre_process_name").set('dummy pre-process for testing purposes') form.textarea(:id => "pre_process_info").set('dummy pre-process for testing purposes')
form.input(:type => "submit").click form.input(:type => "submit").click
Watir::Wait.until(timeout: 30) {$b.execute_script("return jQuery.active") == 0} Watir::Wait.until(timeout: 30) {$b.execute_script("return jQuery.active") == 0}
