Commit dc030f62 authored by Mikaël Salson's avatar Mikaël Salson
vidjil-format.md: Better document _average_read_length
parent ecffd703
...@@ -332,6 +332,11 @@ In the `.analysis` file, this section is intended to describe some specific clon ...@@ -332,6 +332,11 @@ In the `.analysis` file, this section is intended to describe some specific clon
"reads": [], // number of reads in this clones [.vidjil only, required] "reads": [], // number of reads in this clones [.vidjil only, required]
// (with samples.number elements) // (with samples.number elements)
"_average_read_length": [],
// Average read length of the reads clustered in this clone.
// This value allows to draw a genescan-like plot.
"top": 0, // (not documented now) [required] threshold to display/hide the clone "top": 0, // (not documented now) [required] threshold to display/hide the clone
"stats": [] // (not documented now) [.vidjil only] (with sample.number elements) "stats": [] // (not documented now) [.vidjil only] (with sample.number elements)
