Commit daca570f authored by Marc Duez's avatar Marc Duez
server test : debug reset stream
parent 9ca47246
...@@ -97,20 +97,17 @@ fake_file_id = db.sequence_file.insert(sampling_date="1903-02-02", ...@@ -97,20 +97,17 @@ fake_file_id = db.sequence_file.insert(sampling_date="1903-02-02",
# and a fake result for this file # and a fake result for this file
stream = open("../../doc/analysis-example.vidjil", 'rb') stream = open("../../doc/analysis-example.vidjil", 'rb')
gluon.contrib.simplejson.loads(stream.read())
fake_result_id = db.results_file.insert(sequence_file_id = fake_file_id, fake_result_id = db.results_file.insert(sequence_file_id = fake_file_id,
config_id = fake_config_id, config_id = fake_config_id,
run_date = "2014-09-19 00:00:00", run_date = "2014-09-19 00:00:00",
data_file = db.results_file.data_file.store(stream, "plop.data") data_file = db.results_file.data_file.store(stream, "plop.data")
stream.seek(0)
fake_fused_id = db.fused_file.insert(patient_id = fake_patient_id, fake_fused_id = db.fused_file.insert(patient_id = fake_patient_id,
fuse_date = "2014-09-19 00:00:00", fuse_date = "2014-09-19 00:00:00",
fused_file = db.fused_file.fused_file.store(stream, "plop.data") fused_file = db.fused_file.fused_file.store(stream, "plop.data")
db.commit() db.commit()
