Commit d8f7f375 authored by Ryan Herbert's avatar Ryan Herbert
add tests for tokeniser
parent 90af4c1f
QUnit.module("Tokeniser", {
QUnit.test("tokeniser", function(assert) {
var tokeniser = new Tokeniser();
var mock_input = document.createElement('input');
mock_input.value = "foobar";
$(mock_input).data('set-id', ":p foobar");
var token = tokeniser.createToken($(mock_input));
assert.equal(token.innerText, "foobar", "check whether the token text is correct");
var mock_div = document.createElement('div');
tokeniser.tokenise(mock_input, mock_div);
assert.equal(mock_input.value, "", "check that input value is reset");
assert.equal($(mock_input).data('set-id'), undefined, "check that input data set-id is reset");
var mock_div_2 = document.createElement('div');
var mock_span;
for(var i = 0; i < 2; i++) {
mock_span = document.createElement('span');
mock_span.className = 'set_token';
mock_span.innerText = i;
$(mock_span).data('set-id', i);
mock_div_2.appendChild(mock_span);
var wrong_span = document.createElement('span');
$(wrong_span).data('set-id', 'barfoo');
mock_div_2.appendChild(wrong_span);
var read = tokeniser.readTokens(mock_div_2);
assert.equal(read, "0,1", "check whether the token spans are read correctly");
...@@ -49,6 +49,7 @@ ...@@ -49,6 +49,7 @@
<script type="text/javascript" src='../../js/url.js' data-cover></script> <script type="text/javascript" src='../../js/url.js' data-cover></script>
<script type="text/javascript" src='../../js/shortcut.js' data-cover></script> <script type="text/javascript" src='../../js/shortcut.js' data-cover></script>
<script type="text/javascript" src='../../js/speed_test.js' data-cover></script> <script type="text/javascript" src='../../js/speed_test.js' data-cover></script>
<script type="text/javascript" src='../../js/tokeniser.js' data-cover></script>
<script type="text/javascript" src="./testFiles/data_test.js"></script> <script type="text/javascript" src="./testFiles/data_test.js"></script>
<script type="text/javascript" src="./testFiles/test2.analysis"></script> <script type="text/javascript" src="./testFiles/test2.analysis"></script>
...@@ -110,5 +111,6 @@ ...@@ -110,5 +111,6 @@
<script src="./testFiles/url_test.js"></script> <script src="./testFiles/url_test.js"></script>
<script src="./testFiles/shortcut_test.js"></script> <script src="./testFiles/shortcut_test.js"></script>
<script src="./testFiles/speed_test.js"></script> <script src="./testFiles/speed_test.js"></script>
<script src="./testFiles/tokeniser_test.js"></script>
</body> </body>
</html> </html>
