GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
d7302896
d7302896
Mathieu Giraud
task.py: mixcr, remove .vdjca files when there are no longer used
fe822216
server/web2py/applications/vidjil/models/task.py
d7302896
@@ -329,6 +329,7 @@ def run_mixcr(id_file, id_config, id_data, id_fuse, clean_before=False, clean_af
cmd
mixcr
' align --save-reads -t 1 -r '
align_report
args_1
seq_file
out_alignments
cmd
mixcr
align_report
args_1
seq_file
out_alignments
cmd
cmd
cmd
mixcr
' assemble -t 1 -r '
assembly_report
args_2
out_alignments
out_clones
cmd
mixcr
assembly_report
args_2
out_alignments
out_clones
cmd
' && rm '
out_alignments
cmd
cmd
cmd
mixcr
' exportClones --format vidjil -germline -id -name -reads -sequence -top -seg -s '
args_3
out_clones
out_results
cmd
mixcr
args_3
out_clones
out_results
Vidjil Team
@vidjilteam
Mentioned in issue
#1928 (closed)
Nov 29, 2016
Mentioned in issue
#1928 (closed)
Mentioned in issue #1928
Toggle commit list
