Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit d4247df9 authored by Mikaël Salson's avatar Mikaël Salson
tests: No CDR3 should be found on that sequence
Start and end of the junction are too close
parent 0027f326
!LAUNCH: $VIDJIL_DIR/vidjil -c segment -3 -g $VIDJIL_DIR/germline -i $DATA_DIR/no-cdr3.fasta
$ No CDR3 should be found
0:seq1.* IGH SEG.* [{].*[}]
...@@ -74,6 +74,7 @@ BASE=$(basename $file) ...@@ -74,6 +74,7 @@ BASE=$(basename $file)
cd "$DIR" cd "$DIR"
VIDJIL_DIR=../../../ VIDJIL_DIR=../../../
DATA_DIR=../../../data/
OUTPUT_DIR=. OUTPUT_DIR=.
TAP_FILE=${BASE%.*}.tap TAP_FILE=${BASE%.*}.tap
LOG_FILE=${BASE%.*}.log LOG_FILE=${BASE%.*}.log
>seq1
GGGGGTCCCTGAGACTCTCCTGTGCAGCCTCTGGATTCACCTTCAGTAGCTATAGCATGAACTGGGTCCGCCAGGCTCCAGGGAAGGGGCTGGAGTGGGTCTCATCCATTAGTAGTAGTAGTAGTTACATATACTACGCAGACTCAGTGAAGGGCCGATTCACCATCTCCAGAGACAACGCCAAGAACTCACTGTATCTGCAAATGAACAGCCTGAGAGAGGTGGTTATCCTTCCTTGACTACTGGGGCCAGGGAACCCTGGTCACCGTCTCCTCAGGT
\ No newline at end of file
