Commit d3629dcb authored by HERBERT Ryan's avatar HERBERT Ryan Committed by Mikaël Salson
sample_set* some minor refactoring
passing the helper to the view instead of the type in order to call some
helper functions from the view. Notably to fix the add button which only
worked for generic.
parent 4402838e
...@@ -201,7 +201,7 @@ def all(): ...@@ -201,7 +201,7 @@ def all():
return dict(query = result, return dict(query = result,
fields = fields, fields = fields,
type = type, helper = helper,
isAdmin = isAdmin, isAdmin = isAdmin,
reverse = False, reverse = False,
step = step, step = step,
...@@ -3,6 +3,9 @@ class SampleSet(object): ...@@ -3,6 +3,9 @@ class SampleSet(object):
def __init__(self, type): def __init__(self, type):
self.type = type self.type = type
def get_type(self):
return self.type
def __getitem__(self, key): def __getitem__(self, key):
return getattr(self, key, None) return getattr(self, key, None)
...@@ -71,6 +74,9 @@ class SampleSet(object): ...@@ -71,6 +74,9 @@ class SampleSet(object):
row['string'] = [row['name'], row['confs'], row['groups'], str(row['info'])] row['string'] = [row['name'], row['confs'], row['groups'], str(row['info'])]
return filter(lambda row : vidjil_utils.advanced_filter(row['string'], filter_str), data) return filter(lambda row : vidjil_utils.advanced_filter(row['string'], filter_str), data)
def get_add_route(self):
return 'sample_set/add'
def get_info_dict(self, data): def get_info_dict(self, data):
return dict(name = "sample_set : %s" % db.sample_set[data.sample_set_id].sample_type, return dict(name = "sample_set : %s" % db.sample_set[data.sample_set_id].sample_type,
filename = "sample_set_%d" % data.id, filename = "sample_set_%d" % data.id,
...@@ -29,5 +29,8 @@ class Patient(SampleSet): ...@@ -29,5 +29,8 @@ class Patient(SampleSet):
info = data.info info = data.info
return 'patient/add'
def get_data(self, sample_set_id): def get_data(self, sample_set_id):
return db(db.patient.sample_set_id == sample_set_id).select()[0] return db(db.patient.sample_set_id == sample_set_id).select()[0]
...@@ -28,5 +28,8 @@ class Run(SampleSet): ...@@ -28,5 +28,8 @@ class Run(SampleSet):
return 'run/add'
return db(db.run.sample_set_id == sample_set_id).select()[0] return db(db.run.sample_set_id == sample_set_id).select()[0]
...@@ -8,16 +8,16 @@ ...@@ -8,16 +8,16 @@
<div class="db_block"> <div class="db_block">
<div class="db_block_left"> <div class="db_block_left">
search search
<input id="db_filter_input" type="text" value="{{=request.vars["filter"]}}" onchange="db.call('sample_set/all', {'type': '{{=type}}', 'filter' : this.value} )"> <input id="db_filter_input" type="text" value="{{=request.vars["filter"]}}" onchange="db.call('sample_set/all', {'type': '{{=helper.get_type()}}', 'filter' : this.value} )">
</div> </div>
<div class="db_block_right"> <div class="db_block_right">
page: page:
{{ if page > 0: }} {{ if page > 0: }}
<div class="button" onclick="db.call('sample_set/all', {'type': '{{=type}}', 'page': {{=page-1}}})"><</div> <div class="button" onclick="db.call('sample_set/all', {'type': '{{=helper.get_type()}}', 'page': {{=page-1}}})"><</div>
{{ pass }} {{ pass }}
{{= page + 1 }} {{= page + 1 }}
{{if len(query) > step : }} {{if len(query) > step : }}
<div class="button" onclick="db.call('sample_set/all', {'type': '{{=type}}', 'page': {{=page+1}}})">></div> <div class="button" onclick="db.call('sample_set/all', {'type': '{{=helper.get_type()}}', 'page': {{=page+1}}})">></div>
</div> </div>
</div> </div>
...@@ -56,7 +56,7 @@ ...@@ -56,7 +56,7 @@
{{if isAdmin:}} <td onclick="db.call('sample_set/permission', {'id' :'{{=data.id}}'} )" > <i class="icon-key" title="set permissions"></i> </td> {{else:}} <td></td> {{pass}} {{if isAdmin:}} <td onclick="db.call('sample_set/permission', {'id' :'{{=data.id}}'} )" > <i class="icon-key" title="set permissions"></i> </td> {{else:}} <td></td> {{pass}}
{{if data.has_permission:}} {{if data.has_permission:}}
<td onclick="db.call('sample_set/edit', {'id' :'{{=data.id}}'} )" > <i class="icon-pencil-2" title="{{='edit %s information' % 'sample_set'}}"></i> </td> <td onclick="db.call('sample_set/edit', {'id' :'{{=data.id}}'} )" > <i class="icon-pencil-2" title="{{='edit %s information' % 'sample_set'}}"></i> </td>
<td onclick="db.call('sample_set/confirm', {'id' :'{{=data.id}}'} )" > <i class="icon-erase" title="{{='delete %s' % type}}"></i> </td> <td onclick="db.call('sample_set/confirm', {'id' :'{{=data.id}}'} )" > <i class="icon-erase" title="{{='delete %s' % helper.get_type()}}"></i> </td>
{{else:}} <td></td><td></td>{{pass}} {{else:}} <td></td><td></td>{{pass}}
</tr> </tr>
{{pass}} {{pass}}
...@@ -69,7 +69,7 @@ ...@@ -69,7 +69,7 @@
{{if auth.can_create_patient():}} {{if auth.can_create_patient():}}
<span class="button2" onclick="db.call('sample_set/add')"> + new {{=type}} </span> <span class="button2" onclick="db.call('{{=helper.get_add_route()}}')"> + new {{=helper.get_type()}} </span>
<span class="button2" onclick="db.call('sample_set/custom', {'filter': '{{=request.vars['filter']}}' })"> compare samples/patients </span> <span class="button2" onclick="db.call('sample_set/custom', {'filter': '{{=request.vars['filter']}}' })"> compare samples/patients </span>
{{else:}} {{else:}}
<!-- <span class="button2 inactive" onclick="db.call('sample_set/add')" title="you don't have permission to create new {{=type}}"> add sample_set </span> --> <!-- <span class="button2 inactive" onclick="db.call('sample_set/add')" title="you don't have permission to create new {{=type}}"> add sample_set </span> -->
