Commit d218552b authored by Mikaël Salson's avatar Mikaël Salson
Merge branch 'improve_doc' into 'dev'
Documentation on manually launching a backup
See merge request !506
parents 1763f59a 856f8dbd
Pipeline #90155 passed with stages
in 6 minutes and 39 seconds
...@@ -268,7 +268,7 @@ Contact us (<mailto:contact@vidjil.org>) to have more information and help. ...@@ -268,7 +268,7 @@ Contact us (<mailto:contact@vidjil.org>) to have more information and help.
# Docker -- Troubleshooting # Docker -- Troubleshooting
### Error "Can't connect to MySQL server on 'mysql'" ## Error "Can't connect to MySQL server on 'mysql'"
The mysql container is not fully launched. This can happen especially at the first launch. The mysql container is not fully launched. This can happen especially at the first launch.
You may relaunch the containers. You may relaunch the containers.
...@@ -298,6 +298,16 @@ you can look into: ...@@ -298,6 +298,16 @@ you can look into:
If the database does not exist, mysql will display an error after logging in. If the database does not exist, mysql will display an error after logging in.
## Launching manually the backup
The backup should be handled by the backup container. If so, connect to this
container and run (for a full backup, otherwise add the `-i` option when
running `backup.sh`):
```sh
cd /usr/share/vidjil/server
sh backup.sh vidjil /mnt/backup >> /var/log/cron.log 2>&1
# Docker -- Updating a Docker installation # Docker -- Updating a Docker installation
Supports Markdown
