Commit ce500c8d authored by Mathieu Giraud's avatar Mathieu Giraud
vidjil: prepare CHANGELOG for release 2015.01
parent 3cd0f5e6
This changelog concerns the algorithmic part (C++) of Vidjil. This changelog concerns the algorithmic part (C++) of Vidjil.
2015-01-31 The Vidjil Team
* Better TRG and TRD+ parameters (-g). The multi-germline analysis will again be improved in a next release.
* New experimental option (-I) to discard common kmers between different germlines (core/germline.cpp)
* Updated outputs for better traceability (version in .json, germlines on stdout)
* New mechanism to retrieve germline databases (germline/get-saved-germline)
2014-12-22 The Vidjil Team 2014-12-22 The Vidjil Team
* Better multi-germline analysis (-g). This will again be improved in a next release. * Better multi-germline analysis (-g). This will again be improved in a next release.
* New experimental incomplete rearrangement analysis (-i) * New experimental incomplete rearrangement analysis (-i)
