Commit ce025c5b authored by Ryan Herbert's avatar Ryan Herbert Committed by Mikaël Salson
SampleSetList tests: add missing select()
parent 26f49f71
...@@ -46,7 +46,8 @@ class SamplesetlistModel(unittest.TestCase): ...@@ -46,7 +46,8 @@ class SamplesetlistModel(unittest.TestCase):
value = slist.result[0] value = slist.result[0]
set_ids = set([s.id for s in slist.result]) set_ids = set([s.id for s in slist.result])
anon_permissions = list(set([s.id for s in db(auth.vidjil_accessible_query('anon', db.sample_set))]) & set_ids) anon_set_ids = set([s.id for s in db(auth.vidjil_accessible_query('anon', db.sample_set)).select(db.sample_set.id)])
anon_permissions = list(anon_set_ids & set_ids)
self.assertFalse(value.sample_set_id in anon_permissions, "Anon was allowed, when it was not expected to be") self.assertFalse(value.sample_set_id in anon_permissions, "Anon was allowed, when it was not expected to be")
Supports Markdown
