Commit c6fbe30a authored by Mikaël Salson's avatar Mikaël Salson
vidjil.cpp: Inversion in unsegmented output options
The first one must not be the detailed. The detailed is second and
the full detailed is third.
parent 835e1801
...@@ -639,9 +639,9 @@ int main (int argc, char **argv) ...@@ -639,9 +639,9 @@ int main (int argc, char **argv)
break; break;
case 'u': case 'u':
output_unsegmented = output_unsegmented_detail_full ; // -uuu output_unsegmented_detail_full = output_unsegmented_detail; // -uuu
output_unsegmented_detail_full = output_unsegmented_detail; // -uu output_unsegmented_detail = output_unsegmented; // -uu
output_unsegmented_detail = true; // -u output_unsegmented = true ; // -u
break; break;
case 'U': case 'U':
output_segmented = true; output_segmented = true;
