Commit c585279b authored by Mathieu Giraud's avatar Mathieu Giraud
.gitlab-ci.yml: update references to algo
See #2630.
parent c661b652
...@@ -20,7 +20,7 @@ stages: ...@@ -20,7 +20,7 @@ stages:
test_algo_unit: test_algo_unit:
stage: test_unit stage: test_unit
script: make unit script: make -C algo unit
only: only:
- /^feature-a\/.*$/ - /^feature-a\/.*$/
...@@ -32,25 +32,25 @@ test_tools_unit: ...@@ -32,25 +32,25 @@ test_tools_unit:
test_algo_should: test_algo_should:
stage: test_functional stage: test_functional
script: make should script: make -C algo should
only: only:
test_algo_shouldvdj: test_algo_shouldvdj:
stage: test_shouldvdj stage: test_shouldvdj
script: make shouldvdj script: make -C algo shouldvdj
only: only:
algo_valgrind_unit: algo_valgrind_unit:
stage: valgrind_unit stage: valgrind_unit
script: make valgrind_unit script: make -C algo valgrind_unit
only: only:
algo_valgrind_functional: algo_valgrind_functional:
stage: valgrind_functional stage: valgrind_functional
script: make valgrind_should script: make -C algo valgrind_should
when: manual when: manual
only: only:
