Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit c23928ca authored by HERBERT Ryan's avatar HERBERT Ryan
task.py progressively delete fused_files
Fused_files were previously preserved from previous runs. However the
decision has been made to no longer preserve these files as they do not
serve the expected purpose.
parent 8d6525b4
...@@ -520,8 +520,11 @@ def run_fuse(id_file, id_config, id_data, sample_set_id, clean_before=True, clea ...@@ -520,8 +520,11 @@ def run_fuse(id_file, id_config, id_data, sample_set_id, clean_before=True, clea
fused_files = db( ( db.fused_file.config_id == id_config ) & fused_files = db( ( db.fused_file.config_id == id_config ) &
( db.fused_file.sample_set_id == sample_set_id ) ( db.fused_file.sample_set_id == sample_set_id )
).select() ).select()
existing_fused_file = None
if len(fused_files) > 0: if len(fused_files) > 0:
id_fuse = fused_files[0].id fused_file = fused_files[0]
id_fuse = fused_file.id
existing_fused_file = fused_file.fused_file
else: else:
id_fuse = db.fused_file.insert(sample_set_id = sample_set_id, id_fuse = db.fused_file.insert(sample_set_id = sample_set_id,
config_id = id_config) config_id = id_config)
...@@ -535,6 +538,11 @@ def run_fuse(id_file, id_config, id_data, sample_set_id, clean_before=True, clea ...@@ -535,6 +538,11 @@ def run_fuse(id_file, id_config, id_data, sample_set_id, clean_before=True, clea
clean_cmd = "rm -rf " + out_folder clean_cmd = "rm -rf " + out_folder
p = Popen(clean_cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=True) p = Popen(clean_cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=True)
p.wait() p.wait()
# remove previous fused_file if it exists
if existing_fused_file is not None:
clean_cmd = "rm -rf %s/%s" % (out_folder, existing_fused_file)
p.wait()
res = {"message": "[%s] c%s: 'fuse' finished - %s" % (id_data, id_config, db.fused_file[id_fuse].fused_file)} res = {"message": "[%s] c%s: 'fuse' finished - %s" % (id_data, id_config, db.fused_file[id_fuse].fused_file)}
log.info(res) log.info(res)
