Attention une mise à jour du service Gitlab va être effectuée le mardi 14 décembre entre 13h30 et 14h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit c0ef9cbe authored by Ryan Herbert's avatar Ryan Herbert
more consistent hidden fields
ensures that we always use the hidden attribute rather than "display:
none" or a mix of both. The reason being is that setting an element to
"display: none" will not allow it to be displayed by removing the hidden
attribute.
we have a css rule that applies "display: none" to elements that have
the 'hidden' attribute.
JQuery methods hide() and show() add and remove 'display: none'
respectively so we need to steer clear of these methods since they will
interfere with the behaviour of the 'hidden' attribute and the
associated CSS.
parent 365d954f
......@@ -338,10 +338,10 @@ Database.prototype = {
var option = field.options[i];
if (value == option.value){
if (option.getAttribute("required_files") == "1"){
$(".file_2").hide();
$(".file_2").attr('hidden', true);
$(".upload_file_2").val("");
}else{
$(".file_2").show();
$(".file_2").attr('hidden', false);
......@@ -328,7 +328,6 @@ FileFormBuilder.prototype.build_jstree = function() {
d.className += " jstree_container";
if (!this.source) {
d.hidden = true;
d.style.display = 'none';
var sel = document.createTextNode('selected');
......@@ -18,7 +18,7 @@
onchange="db.upload_file_onChange('file_filename_{{=i}}', this.value)"
><span>* (.fa, .fastq, .fa.gz, .fastq.gz, .clntab)</span>
</div>
<div id="file_2_{{=i}}" class="field_div file_2" {{if source_module_active:}} hidden {{pass}}>
<div id="file_2_{{=i}}" class="field_div file_2" hidden>
<label for="file_upload_2_{{=i}}" id="file2__label_{{=i}}"> file 2 </label>
<input class="upload_field form-control" id="file_upload_2_{{=i}}" type="file"
