Commit bee86327 authored by flothoni's avatar flothoni Committed by Mikaël Salson
Update view sample_set.html; fix launch button filter
Link to #3827
parent 5d797b9f
Pipeline #138447 failed with stages
in 8 minutes and 38 seconds
...@@ -139,7 +139,7 @@ ...@@ -139,7 +139,7 @@
<td></td><td></td><td></td><td></td> <td></td><td></td><td></td><td></td>
{{pass}} {{pass}}
<td> <td>
{{if row.sequence_file.data_file != None and ( row.results_file.id == None and ( status not in ["RUNNING", "QUEUED", "ASSIGNED"]) ) and (not has_pre_process or row.sequence_file.pre_process_flag != None) :}} {{if row.sequence_file.data_file != None and ( row.results_file.id != None or ( status not in ["RUNNING", "QUEUED", "ASSIGNED"]) ) and (not has_pre_process or row.sequence_file.pre_process_flag != None) :}}
{{if auth.can_process_sample_set(request.vars['id']) and (config_id > 0 and auth.can_use_config(config_id)) :}} {{if auth.can_process_sample_set(request.vars['id']) and (config_id > 0 and auth.can_use_config(config_id)) :}}
<span class="pointer" onclick="db.call('default/run_request', { 'sequence_file_id' : '{{=row.sequence_file.id}}', 'sample_set_id' : {{=request.vars["id"]}}, 'config_id' : {{=config_id}} } )"><i class="icon-cog-2" title="Run the selected configuration for this file"></i></span> <span class="pointer" onclick="db.call('default/run_request', { 'sequence_file_id' : '{{=row.sequence_file.id}}', 'sample_set_id' : {{=request.vars["id"]}}, 'config_id' : {{=config_id}} } )"><i class="icon-cog-2" title="Run the selected configuration for this file"></i></span>
{{pass}} {{pass}}
