Commit b8c33ebb authored by HERBERT Ryan's avatar HERBERT Ryan
export.js run and software end report
Moved software and parameters to the end of the sample log
parent 8b6e23db
...@@ -94,6 +94,7 @@ Report.prototype = { ...@@ -94,6 +94,7 @@ Report.prototype = {
self.sampleLog() self.sampleLog()
.softwareInfo(self.m.t)
self.m.resize() self.m.resize()
self.m.resume() self.m.resume()
...@@ -220,8 +221,6 @@ Report.prototype = { ...@@ -220,8 +221,6 @@ Report.prototype = {
var content = [ var content = [
{'label': "Filename:" , value : this.m.samples.original_names[time]}, {'label': "Filename:" , value : this.m.samples.original_names[time]},
{'label': "Sample date:" , value : this.m.getSampleTime(time)}, {'label': "Sample date:" , value : this.m.getSampleTime(time)},
{'label': "Software used:" , value : this.m.getSoftVersionTime(time)},
{'label': "Parameters:" , value : this.m.getCommandTime(time)},
{'label': "Analysis date:" , value : this.m.getTimestampTime(time)} {'label': "Analysis date:" , value : this.m.getTimestampTime(time)}
...@@ -243,6 +242,25 @@ Report.prototype = { ...@@ -243,6 +242,25 @@ Report.prototype = {
return this return this
softwareInfo : function(time) {
var sinfo = this.container("Software info("+this.m.getStrTime(time)+")");
var div = $('<div/>', {'class': 'flex'}).appendTo(sinfo);
var content = [
var table = $('<table/>', {'class': 'info-table'}).appendTo(div);
for ( var key in content ) {
var v = content[key];
var row = $('<tr/>').appendTo(table);
$('<td/>', {'class': 'label', 'text': v.label}).appendTo(row);
$('<td/>', {'text': v.value}).appendTo(row);
return this;
svg_graph : function(norm) { svg_graph : function(norm) {
if (typeof norm == "undefined") norm = -1 if (typeof norm == "undefined") norm = -1
Supports Markdown
