Commit b872b04c authored by Cyprien Borée's avatar Cyprien Borée
Fix testGetMultiResults when there is only unknown K-mer
The previous test was only looking for a single unknown K-mer in the map even
though the map shouldn't contain anything else from unknown K-mers.
Indeed when there is no K-mers in the automaton that match the input sequence,
then the map contains only unknown K-mers.
For more informations, see #3303.
parent 59aa4797
Pipeline #29922 passed with stages
in 28 minutes and 51 seconds
...@@ -110,16 +110,13 @@ void testGetMultiResults(){ ...@@ -110,16 +110,13 @@ void testGetMultiResults(){
seqtype seq4 = "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"; seqtype seq4 = "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA";
results = aho.getMultiResults(seq4); results = aho.getMultiResults(seq4);
TAP_TEST(results.size() <= 1, TEST_AC_OCCURENCES, errorSize); TAP_TEST(results.size() <= 1, TEST_AC_OCCURENCES, errorSize);
/* Check if there is at least one Kmer unknown when no matching K-mer */ If there is K-mers in automaton doesn't match the sequence, the map must
unsigned int i = 0; return only unknown K-mers.
for(auto const& x : results){ for(auto const& x : results){
if(x.first.toStringValues() == AFFECT_UNKNOWN_TO_STRING){ TAP_TEST(x.first == AFFECT_UNKNOWN, TEST_AC_OCCURENCES, "Ambiguous Kmer not found");
break;
++i;
TAP_TEST(i < results.size(), TEST_AC_OCCURENCES, "Ambiguous Kmer not found");
void testRCInsertAcAutomaton() { void testRCInsertAcAutomaton() {
