Commit b74e0173 authored by Mathieu Giraud's avatar Mathieu Giraud
Merge branch 'feature-a/3393-binreadstorage-use-bins-when-necessary' into 'dev'
feature-a/3393-binreadstorage-use-bins-when-necessary into dev
Closes #3393 and #3395
See merge request !267
parents d1d409aa 773f29b3
Pipeline #36122 passed with stage
in 5 seconds
...@@ -17,6 +17,11 @@ BinReadStorage::BinReadStorage() ...@@ -17,6 +17,11 @@ BinReadStorage::BinReadStorage()
nb_inserted(0), nb_stored(0), smallest_bin_not_empty(~0),label(),inited(false) {} nb_inserted(0), nb_stored(0), smallest_bin_not_empty(~0),label(),inited(false) {}
void BinReadStorage::init(size_t nb_bins, size_t max_score, const VirtualReadScore *vrs, bool no_list) { void BinReadStorage::init(size_t nb_bins, size_t max_score, const VirtualReadScore *vrs, bool no_list) {
this->max_bins = nb_bins;
__init(0, max_score, vrs, no_list);
void BinReadStorage::__init(size_t nb_bins, size_t max_score, const VirtualReadScore *vrs, bool no_list) {
this->all_read_lengths = 0; this->all_read_lengths = 0;
if (inited) if (inited)
return; return;
...@@ -37,7 +42,30 @@ void BinReadStorage::init(size_t nb_bins, size_t max_score, const VirtualReadSco ...@@ -37,7 +42,30 @@ void BinReadStorage::init(size_t nb_bins, size_t max_score, const VirtualReadSco
inited=true; inited=true;
void BinReadStorage::reallocate(){
list<Sequence> tmpBin;
if (bins)
tmpBin = bins[0];
free_objects();
smallest_bin_not_empty = ~0;
total_nb_scores = 0;
nb_stored = 0;
inited = false;
__init(max_bins, max_score, scorer, tmpBin.size() == 0);
for(auto s : tmpBin){
this->add(s);
nb_inserted -= nb_stored;
BinReadStorage::~BinReadStorage() { BinReadStorage::~BinReadStorage() {
free_objects();
void BinReadStorage::free_objects() {
if (bins) if (bins)
delete [] bins; delete [] bins;
if (score_bins) { if (score_bins) {
...@@ -62,6 +90,9 @@ void BinReadStorage::addScore(size_t bin, float score) { ...@@ -62,6 +90,9 @@ void BinReadStorage::addScore(size_t bin, float score) {
void BinReadStorage::add(Sequence &s) { void BinReadStorage::add(Sequence &s) {
if(nb_stored == getMaxNbReadsStored() && nb_inserted == nb_stored){
reallocate();
float score = scorer->getScore(s); float score = scorer->getScore(s);
size_t bin = scoreToBin(score); size_t bin = scoreToBin(score);
addScore(bin, score); addScore(bin, score);
...@@ -68,6 +68,7 @@ class VirtualReadStorage { ...@@ -68,6 +68,7 @@ class VirtualReadStorage {
class BinReadStorage: public VirtualReadStorage { class BinReadStorage: public VirtualReadStorage {
private: private:
size_t max_bins;
size_t nb_bins; size_t nb_bins;
list<Sequence> *bins; list<Sequence> *bins;
double *score_bins; double *score_bins;
...@@ -87,6 +88,7 @@ public: ...@@ -87,6 +88,7 @@ public:
* nb_bins are created and the maximal score for the reads that will be added is assumed * nb_bins are created and the maximal score for the reads that will be added is assumed
* to be max_score. If higher score are met, they are put in the nb_bins+1 bin. * to be max_score. If higher score are met, they are put in the nb_bins+1 bin.
* The class doesn't destruct the VirtualReadScore. It is the responsability of the caller. * The class doesn't destruct the VirtualReadScore. It is the responsability of the caller.
* May not build as many as nb_bins to save memory.
* @pre all scores must be >= 0 * @pre all scores must be >= 0
* @param no_list: don't create a list (useful for storing only stats, * @param no_list: don't create a list (useful for storing only stats,
* false by default: lists are created). If the option is set to true, the * false by default: lists are created). If the option is set to true, the
...@@ -94,7 +96,24 @@ public: ...@@ -94,7 +96,24 @@ public:
void init(size_t nb_bins, size_t max_score, const VirtualReadScore *vrs, bool no_list = false); void init(size_t nb_bins, size_t max_score, const VirtualReadScore *vrs, bool no_list = false);
private:
* Private function used by init() that actually does the job. It actually creates the number of bins
* given in parameter.
void __init(size_t nb_bins, size_t max_score, const VirtualReadScore *vrs, bool no_list = false);
void free_objects();
public:
* If the bin is full we need, the storage needs to be reallocated to have more memory.
void reallocate();
~BinReadStorage(); ~BinReadStorage();
void add(Sequence &s); void add(Sequence &s);
...@@ -266,12 +266,12 @@ void WindowsStorage::clearSequences(){ ...@@ -266,12 +266,12 @@ void WindowsStorage::clearSequences(){
seqs_by_window.clear(); seqs_by_window.clear();
json WindowsStorage::sortedWindowsToJson(map <junction, json> json_data_segment, int max_json_output) { json WindowsStorage::sortedWindowsToJson(map <junction, json> json_data_segment, int max_json_output, bool delete_all) {
json windowsArray; json windowsArray;
int top = 1; int top = 1;
for (list<pair <junction, size_t> >::const_iterator it = sort_all_windows.begin(); for (list<pair <junction, size_t> >::const_iterator it = sort_all_windows.begin();
it != sort_all_windows.end(); ++it) it != sort_all_windows.end(); )
json windowsList; json windowsList;
...@@ -295,6 +295,13 @@ json WindowsStorage::sortedWindowsToJson(map <junction, json> json_data_segment, ...@@ -295,6 +295,13 @@ json WindowsStorage::sortedWindowsToJson(map <junction, json> json_data_segment,
windowsArray.push_back(windowsList); windowsArray.push_back(windowsList);
if (delete_all) {
germline_by_window.erase(it->first);
status_by_window.erase(it->first);
it = sort_all_windows.erase(it);
} else {
it++;
if (top == max_json_output + 1) if (top == max_json_output + 1)
break ; break ;
...@@ -218,8 +218,13 @@ class WindowsStorage { ...@@ -218,8 +218,13 @@ class WindowsStorage {
* @max_json_output: maximal number of windows to output (<= 0: no limit) * @max_json_output: maximal number of windows to output (<= 0: no limit)
ostream &printSortedWindows(ostream &os); ostream &printSortedWindows(ostream &os);
json sortedWindowsToJson(map<junction, json> json_data_segment, int max_json_output); /**
* @param delete_all: Delete the objects while they are inserted into the JSON. This prevents the memory
* from continously increasing (see #2120, #3387)
* @return a JSON object containing all the information
json sortedWindowsToJson(map<junction, json> json_data_segment, int max_json_output, bool delete_all=false);
* Clear the seqs_by_window map. * Clear the seqs_by_window map.
...@@ -9,13 +9,13 @@ void testBinReadStorage() { ...@@ -9,13 +9,13 @@ void testBinReadStorage() {
TAP_TEST_EQUAL(reads.scoreToBin(0), 0, TEST_BRS_SCORE_TO_BIN, ""); TAP_TEST_EQUAL(reads.scoreToBin(0), 0, TEST_BRS_SCORE_TO_BIN, "");
TAP_TEST_EQUAL(reads.scoreToBin(2), 0, TEST_BRS_SCORE_TO_BIN, ""); TAP_TEST_EQUAL(reads.scoreToBin(2), 0, TEST_BRS_SCORE_TO_BIN, "");
TAP_TEST_EQUAL(reads.scoreToBin(10), 2, TEST_BRS_SCORE_TO_BIN, ""); TAP_TEST_EQUAL(reads.scoreToBin(10), 0, TEST_BRS_SCORE_TO_BIN, "");
TAP_TEST_EQUAL(reads.scoreToBin(11), 3, TEST_BRS_SCORE_TO_BIN, ""); TAP_TEST_EQUAL(reads.scoreToBin(11), 0, TEST_BRS_SCORE_TO_BIN, "");
TAP_TEST_EQUAL(reads.scoreToBin(5), 1, TEST_BRS_SCORE_TO_BIN, ""); TAP_TEST_EQUAL(reads.scoreToBin(5), 0, TEST_BRS_SCORE_TO_BIN, "");
Sequence seq1 = {"label", "l", "GAGAG", "", 0}; Sequence seq1 = {"label", "l", "GAGAG", "", 0};
reads.add(seq1); reads.add(seq1);
TAP_TEST_EQUAL(reads.smallest_bin_not_empty, 1, TEST_BRS_SBNE, ""); TAP_TEST_EQUAL(reads.smallest_bin_not_empty, 0, TEST_BRS_SBNE, "");
TAP_TEST_EQUAL(reads.getNbInserted(), 1, TEST_BRS_GET_NB_INSERTED, ""); TAP_TEST_EQUAL(reads.getNbInserted(), 1, TEST_BRS_GET_NB_INSERTED, "");
TAP_TEST_EQUAL(reads.getNbStored(), 1, TEST_BRS_GET_NB_STORED, ""); TAP_TEST_EQUAL(reads.getNbStored(), 1, TEST_BRS_GET_NB_STORED, "");
TAP_TEST(reads.getScoreBySeq(seq1) == 5 TAP_TEST(reads.getScoreBySeq(seq1) == 5
...@@ -27,9 +27,9 @@ void testBinReadStorage() { ...@@ -27,9 +27,9 @@ void testBinReadStorage() {
TAP_TEST_EQUAL(reads.smallest_bin_not_empty, 0, TEST_BRS_SBNE, ""); TAP_TEST_EQUAL(reads.smallest_bin_not_empty, 0, TEST_BRS_SBNE, "");
TAP_TEST_EQUAL(reads.getNbInserted(), 2, TEST_BRS_GET_NB_INSERTED, ""); TAP_TEST_EQUAL(reads.getNbInserted(), 2, TEST_BRS_GET_NB_INSERTED, "");
TAP_TEST_EQUAL(reads.getNbStored(), 2, TEST_BRS_GET_NB_STORED, ""); TAP_TEST_EQUAL(reads.getNbStored(), 2, TEST_BRS_GET_NB_STORED, "");
TAP_TEST(reads.getScoreBySeq(seq2) == 2 TAP_TEST_EQUAL(reads.getScoreBySeq(seq2), 7, TEST_BRS_GET_NB_STORED, "");
&& reads.getScoreByScore(2.) == 2 TAP_TEST_EQUAL(reads.getScoreByScore(2.), 7, TEST_BRS_GET_NB_STORED, "");
&& reads.getScore(0) == 2, TEST_BRS_GET_SCORE, ""); TAP_TEST_EQUAL(reads.getScore(0), 7, TEST_BRS_GET_NB_STORED, "");
TAP_TEST_EQUAL(reads.getScore(), 7, TEST_BRS_GET_SCORE, ""); TAP_TEST_EQUAL(reads.getScore(), 7, TEST_BRS_GET_SCORE, "");
TAP_TEST_EQUAL(reads.getAverageScore(), 3.5, TEST_BRS_GET_AVG_SCORE, ""); TAP_TEST_EQUAL(reads.getAverageScore(), 3.5, TEST_BRS_GET_AVG_SCORE, "");
...@@ -39,9 +39,9 @@ void testBinReadStorage() { ...@@ -39,9 +39,9 @@ void testBinReadStorage() {
TAP_TEST_EQUAL(reads.getNbInserted(), 3, TEST_BRS_GET_NB_INSERTED, ""); TAP_TEST_EQUAL(reads.getNbInserted(), 3, TEST_BRS_GET_NB_INSERTED, "");
TAP_TEST_EQUAL(reads.getNbStored(), 3, TEST_BRS_GET_NB_STORED, ""); TAP_TEST_EQUAL(reads.getNbStored(), 3, TEST_BRS_GET_NB_STORED, "");
TAP_TEST(reads.getScoreBySeq(seq3) == 10 TAP_TEST_EQUAL(reads.getScoreBySeq(seq3), 17, TEST_BRS_GET_NB_STORED, "");
&& reads.getScoreByScore(10.) == 10 TAP_TEST_EQUAL(reads.getScoreByScore(10.), 17, TEST_BRS_GET_NB_STORED, "");
&& reads.getScore(2) == 10, TEST_BRS_GET_SCORE, ""); TAP_TEST_EQUAL(reads.getScore(2), 17, TEST_BRS_GET_SCORE, "");
Sequence seq4 = {"label4", "l4", "AGAGACAGTA", "", 0}; Sequence seq4 = {"label4", "l4", "AGAGACAGTA", "", 0};
reads.add(seq4); reads.add(seq4);
