Commit b6c52a49 authored by Mathieu Giraud's avatar Mathieu Giraud
core/output.cpp: remove duplicate field
Following a discussion with J. V. Heiden.
parent b118541a
...@@ -156,7 +156,6 @@ map <string, string> CloneOutputAIRR::fields() ...@@ -156,7 +156,6 @@ map <string, string> CloneOutputAIRR::fields()
fields["duplicate_count"] = string_of_int(reads()); fields["duplicate_count"] = string_of_int(reads());
fields["sequence_id"] = get("id"); fields["sequence_id"] = get("id");
fields["clone_id"] = get("id");
fields["sequence"] = get("sequence"); fields["sequence"] = get("sequence");
fields["v_call"] = get(KEY_SEG, "5", "name"); fields["v_call"] = get(KEY_SEG, "5", "name");
fields["d_call"] = get(KEY_SEG, "4", "name"); fields["d_call"] = get(KEY_SEG, "4", "name");
...@@ -191,7 +190,6 @@ void SampleOutputAIRR::out(ostream &s) ...@@ -191,7 +190,6 @@ void SampleOutputAIRR::out(ostream &s)
"sequence_alignment", "sequence_alignment",
"germline_alignment", "germline_alignment",
"v_cigar", "d_cigar", "j_cigar", "v_cigar", "d_cigar", "j_cigar",
"clone_id"
