Commit b5b2f4fc authored by Thonier Florian's avatar Thonier Florian
js/numerical_axis.js : bug correction link to #2540
modifiy the min value to start the axe. Now start at the minimal value
change number_step
change label of axis to add minimal value
parent 487af082
...@@ -184,11 +184,6 @@ NumericalAxis.prototype = Object.create(GenericAxis.prototype); ...@@ -184,11 +184,6 @@ NumericalAxis.prototype = Object.create(GenericAxis.prototype);
}else{ }else{
var nb_steps = this.NB_STEPS_IN_AXIS-1 var nb_steps = this.NB_STEPS_IN_AXIS-1
undefined_min = min undefined_min = min
// Recover the initial min value
if (has_undefined) {
min = (min*this.NB_STEPS_IN_AXIS + max)/(this.NB_STEPS_IN_AXIS + 1)
nb_step = this.computeSteps(max, nb_steps); nb_step = this.computeSteps(max, nb_steps);
h = (max-min)/nb_steps h = (max-min)/nb_steps
...@@ -198,10 +193,10 @@ NumericalAxis.prototype = Object.create(GenericAxis.prototype); ...@@ -198,10 +193,10 @@ NumericalAxis.prototype = Object.create(GenericAxis.prototype);
this.labels.push(this.label("line", (this.reverse) ? 0 : 1, "?")) this.labels.push(this.label("line", (this.reverse) ? 0 : 1, "?"))
// Shift the start when there is an undefined value // Shift the start when there is an undefined value
var start_shift = (min - undefined_min)/(max-undefined_min) var start_shift = (min - undefined_min)/(max-undefined_min)
for (var j = 0; j <= nb_steps; j++) { for (var j = 0; j <= nb_steps-1; j++) {
pos = (h*j)*(1/delta); pos = (h*j)*(1/delta);
text = this.getLabelText(h*j); text = this.getLabelText(min + h*j);
if (this.reverse) pos = 1 - pos; if (this.reverse) pos = 1 - pos;
if (!display_label) text = ""; if (!display_label) text = "";
this.addLabel("line", text, pos, text); this.addLabel("line", text, pos, text);
...@@ -210,7 +205,7 @@ NumericalAxis.prototype = Object.create(GenericAxis.prototype); ...@@ -210,7 +205,7 @@ NumericalAxis.prototype = Object.create(GenericAxis.prototype);
NumericalAxis.prototype.computeSteps = function(min, max, nb_steps) { NumericalAxis.prototype.computeSteps = function(min, max, nb_steps) {
var steps = nb_steps; var steps = nb_steps+1;
if (Math.abs(max - min) < nb_steps) { if (Math.abs(max - min) < nb_steps) {
steps = Math.abs(max - min) steps = Math.abs(max - min)
