Commit b0a89fd6 authored by flothoni's avatar flothoni Committed by Mathieu Giraud
pear_log_converter: add a scipt to convert pear log to json format
With this script, we have the possibility to get structured datas from the pear preprocess to use them into the server, for quality, warning, ...
link to #3054 #3049 #3154
parent 9ce7a54c
#!/usr/bin/env python
#-*- coding: utf-8 -*-
# Script by Florian Thonier
# florian@vidjil.org
import operator
import sys, os
import json
from operator import itemgetter
from optparse import OptionParser #@UnusedWildImport
from _collections import defaultdict
VERSION = "0.02"
TIMESTAMP = "2018-04-27"
def get_value(line):
''' Return the value from a line '''
return line.split(': ')[1]
def convert_value(line):
''' Return the values from reads result lines '''
raw_value = get_value(line)
numbers = raw_value.split("(")[0].replace(" ","").split("/")
return numbers
def pear_converter(fileIn, fileOut):
''' Read line by line the log file, store data into a dict, and export it as json '''
json_data = defaultdict(lambda: {})
fi = open( fileIn, "r")
fo = open( fileOut, "w")
for line in fi:
line = line.replace("\n", "")
### version, setting and paramters
if "PEAR v" in line :
json_data["settings"]["version"] = line
elif "Forward reads file" in line :
json_data["settings"]["forward_file"] = get_value(line)
elif "Reverse reads file" in line :
json_data["settings"]["reverse_file"] = get_value(line)
elif "PHRED" in line :
json_data["settings"]["phred"] = get_value(line)
elif "Scoring method" in line :
json_data["settings"]["scoring_methode"] = get_value(line)
elif "Minimum overlap" in line :
json_data["settings"]["minimum_overlap"] = get_value(line)
### bases frequencies
elif "A:" in line :
json_data["base_frequency"]["base_frequency_a"] = get_value(line)
elif "C:" in line :
json_data["base_frequency"]["base_frequency_c"] = get_value(line)
elif "G:" in line :
json_data["base_frequency"]["base_frequency_g"] = get_value(line)
elif "T:" in line :
json_data["base_frequency"]["base_frequency_t"] = get_value(line)
elif "uncalled bases" in line :
json_data["base_frequency"]["uncalled_base"] = line.replace(" uncalled bases", "").replace(" ", "")
### output file
elif "Assembled reads file" in line :
json_data["output_file"]["assembled_reads"] = get_value(line)
elif "Discarded reads file" in line :
json_data["output_file"]["discarded_reads"] = get_value(line)
elif "Unassembled forward reads file" in line :
json_data["output_file"]["unassembled_forward"] = get_value(line)
elif "Unassembled reverse reads file" in line :
json_data["output_file"]["unassembled_reverse"] = get_value(line)
### number of reads
elif "Assembled reads" in line :
json_data["reads"]["reads_assembled_number"] = convert_value(line)[0].replace(",","")
json_data["reads"]["reads_total_number"] = convert_value(line)[1].replace(",","")
elif "Discarded reads" in line :
json_data["reads"]["reads_discarded_number"] = convert_value(line)[0].replace(",","")
elif "Not assembled reads" in line :
json_data["reads"]["reads_not_assembled_number"] = convert_value(line)[0].replace(",","")
### Warnings
json_data["warning"] = []
# assembled reads
percentage_not_assembled = json_data["reads"]["reads_not_assembled_number"] / json_data["reads"]["reads_total_number"]
if percentage_not_assembled > 50.00 :
json_data["warning"].append("Very few reads assembled")
elif percentage_not_assembled > 20.00 :
json_data["warning"].append("Few reads assembled")
# discarded reads
percentage_discarded = json_data["reads"]["reads_discarded_number"] / json_data["reads"]["reads_total_number"]
if percentage_discarded > 10.00 :
json_data["warning"].append("High level of discarded reads")
### export as json
try:
json.dump(json_data, fo, sort_keys=True, indent=4, ensure_ascii=False)
print("Dump : %s" % (fileOut))
fo.close()
except: # pragma: no cover
print("Dump : FAILED" )
return -1
return
if __name__ == '__main__':
#print( description )
### Description ###
usage = "Convert the result of pear preprocess log into a json file.\n"
usage += "usage: %prog -i input_pear_log -o output.json"
parser = OptionParser(usage=usage)
### Options ###
parser.add_option("-v", "--verbose",
action="store_true", dest="verbose", default=True,
help="make lots of noise [default]")
parser.add_option("-i", "--input",
metavar="FILE", help="input log file from PEAR merging")
parser.add_option("-o", "--output",
metavar="FILE", help="output file in json format.")
### Getter des options ###
argv = sys.argv
(options, argv) = parser.parse_args(argv)
if not options.input: # if filename is not given
parser.error('input-log file not given')
if not options.output: # if filename is not given
parser.error('output file not given')
if not ".json" in options.output: # if extension is not given
options.output = options.output + ".json"
pear_converter(options.input, options.output )
