Commit b0882b22 authored by Mathieu Giraud's avatar Mathieu Giraud
core/kmeraffect.{h,cpp}: remove KmerStringAffect
KmerStringAffect is no more used in the code.
If one day we would like to "store more things" in the affectations,
we could still extend KmerAffect with a pointer to something else.
parent 782ebd2f
...@@ -166,109 +166,3 @@ ostream &operator<<(ostream &os, const KmerAffect &kmer) { ...@@ -166,109 +166,3 @@ ostream &operator<<(ostream &os, const KmerAffect &kmer) {
return os; return os;
KmerStringAffect::KmerStringAffect() {
label = "";
strand = 0;
KmerStringAffect::KmerStringAffect(const KmerStringAffect &ksa):
label(ksa.label),strand(ksa.strand){}
KmerStringAffect::KmerStringAffect(const string &label,
int strand) {
this->label = label;
this->strand = strand;
KmerStringAffect &KmerStringAffect::operator+=(const KmerStringAffect &kmer) {
if (*this != kmer) {
if (*this == KSA_UNKNOWN)
// Not defined yet
*this = kmer;
else if (*this != KSA_AMBIGUOUS) {
if (this->label == kmer.label)
// Different strand but same label, put ambiguous
*this = KSA_AMBIGUOUS;
else
// Ambiguous: different labels
} // else we are already ambiguous, stay as is.
return *this;
KmerStringAffect &KmerStringAffect::operator=(const KmerStringAffect &ka) {
label = ka.label;
strand = ka.strand;
return *this;
KmerStringAffect KmerStringAffect::getAmbiguous() {
return KSA_AMBIGUOUS;
int KmerStringAffect::getStrand() const {
return (isUnknown() || isAmbiguous()) ? 0 : strand;
string KmerStringAffect::getLabel() const {
return label;
KmerStringAffect KmerStringAffect::getUnknown() {
return KSA_UNKNOWN;
bool KmerStringAffect::isAmbiguous() const {
return *this == KSA_AMBIGUOUS;
bool KmerStringAffect::isUnknown() const {
return *this == KSA_UNKNOWN;
string KmerStringAffect::toString() const {
if (isUnknown()) {
return " _";
switch(strand) {
case 1:
return "+"+label;
case -1:
return "-"+label;
default:
return " ?";
bool operator==(const KmerStringAffect &k1, const KmerStringAffect &k2) {
return k1.strand == k2.strand && (k1.label == k2.label || k1.strand == 0);
bool operator!=(const KmerStringAffect &k1, const KmerStringAffect &k2) {
return ! (k1 == k2);
bool operator<(const KmerStringAffect &k1, const KmerStringAffect &k2) {
return k1.label < k2.label || (k1.label == k2.label && k1.strand < k2.strand);
bool operator>(const KmerStringAffect &k1, const KmerStringAffect &k2) {
return k1.label > k2.label || (k1.label == k2.label && k1.strand > k2.strand);
bool operator<=(const KmerStringAffect &k1, const KmerStringAffect &k2) {
return ! (k1 > k2);
bool operator>=(const KmerStringAffect &k1, const KmerStringAffect &k2) {
return ! (k1 < k2);
ostream &operator<<(ostream &os, const KmerStringAffect &kmer) {
os << kmer.toString();
return os;
bool KmerStringAffect::hasRevcompSymetry() {
return false;
...@@ -160,94 +160,4 @@ const KmerAffect AFFECT_J_BWD = KmerAffect("J", -1); ...@@ -160,94 +160,4 @@ const KmerAffect AFFECT_J_BWD = KmerAffect("J", -1);
* This class represents the affectation with a string for the label. Two
* constants are defined representing affectation that are either unknown
* (KSA_UNKNOWN) or ambiguous (KSA_AMBIGUOUS).
class KmerStringAffect {
public:
string label;
int strand;
* Construct an unknown affectation.
* @post isUnknown()
KmerStringAffect();
KmerStringAffect(const KmerStringAffect &);
* Construct an affectation as stated by the parameters
* @post affect_strand(affect) == strand AND affect_char(affect) == kmer[0]
KmerStringAffect(const string &label, int strand=1);
* Add another affectation to the current one.
* @post The current affectation is not modified if the parameter is the same
* affectation as the current one.
* If the current affectation is unknown, the affectation is set to the
* parameter.
* If the label is the same but the strand is different, the strand is
* arbitrarily put to forward.
* In the other cases, the affectation is set to ambiguous.
KmerStringAffect &operator+=(const KmerStringAffect &);
* Affectation
KmerStringAffect &operator=(const KmerStringAffect &ka);
* @return the ambiguous affectation
static KmerStringAffect getAmbiguous();
* @return the strand of the affectation
* -1 for backward
* 1 for forward
* 0 for unknown or ambiguous
int getStrand() const;
* @return the label of the affectation.
string getLabel() const;
* @return the unknown affectation
static KmerStringAffect getUnknown();
* @return true iff the class does not take care of the strand
* (false in our case).
static bool hasRevcompSymetry();
* @return true iff the affectation should be considered as ambiguous.
bool isAmbiguous() const;
* @return true iff the affectation is unkwown yet.
bool isUnknown() const;
string toString() const;
bool operator!=(const KmerStringAffect &k1, const KmerStringAffect &k2);
bool operator==(const KmerStringAffect &k1, const KmerStringAffect &k2);
bool operator<(const KmerStringAffect &k1, const KmerStringAffect &k2);
bool operator>(const KmerStringAffect &k1, const KmerStringAffect &k2);
bool operator<=(const KmerStringAffect &k1, const KmerStringAffect &k2);
bool operator>=(const KmerStringAffect &k1, const KmerStringAffect &k2);
ostream &operator<<(ostream &os, const KmerStringAffect &kmer);
const KmerStringAffect KSA_UNKNOWN = KmerStringAffect();
const KmerStringAffect KSA_AMBIGUOUS = KmerStringAffect("", 2);
#endif #endif
