Commit b0053cd2 authored by Mathieu Giraud's avatar Mathieu Giraud
format_json.py: 2to3
parent 49764000
from __future__ import print_function
import json import json
import sys import sys
from collections import OrderedDict from collections import OrderedDict
...@@ -12,8 +13,8 @@ parser.add_argument('file', nargs='?', type=argparse.FileType('r'), default=sys. ...@@ -12,8 +13,8 @@ parser.add_argument('file', nargs='?', type=argparse.FileType('r'), default=sys.
args = parser.parse_args() args = parser.parse_args()
json_data = args.file.read() json_data = args.file.read()
print json.dumps(json.loads(json_data, object_pairs_hook=OrderedDict), print(json.dumps(json.loads(json_data, object_pairs_hook=OrderedDict),
sort_keys=not args.unsorted, sort_keys=not args.unsorted,
indent=None if args.one_line else 2) indent=None if args.one_line else 2))
