Commit af119810 authored by Marc Duez's avatar Marc Duez
server : autodelete file if the associated database row is removed
parent edea84d3
...@@ -104,7 +104,7 @@ db.define_table('sequence_file', ...@@ -104,7 +104,7 @@ db.define_table('sequence_file',
Field('sequencer','text'), Field('sequencer','text'),
Field('producer','text'), Field('producer','text'),
Field('size_file','integer'), Field('size_file','integer'),
Field('data_file', 'upload', length=1000000000000)) Field('data_file', 'upload', length=1000000000000, autodelete=True))
...@@ -128,21 +128,21 @@ db.define_table('data_file', ...@@ -128,21 +128,21 @@ db.define_table('data_file',
Field('config_id', 'reference config'), Field('config_id', 'reference config'),
Field('run_date','date'), Field('run_date','date'),
Field('scheduler_task_id', 'integer'), Field('scheduler_task_id', 'integer'),
db.define_table('fused_file', db.define_table('fused_file',
Field('patient_id', 'reference patient'), Field('patient_id', 'reference patient'),
Field('fuse_date','date'), Field('fuse_date','date'),
Field('status', 'string'), Field('status', 'string'),
Field('fused_file', 'upload', length=1000000000000)) Field('fused_file', 'upload', length=1000000000000, autodelete=True))
db.define_table('analysis_file', db.define_table('analysis_file',
Field('analyze_date','date'), Field('analyze_date','date'),
Field('analysis_file', 'upload', length=1000000000000)) Field('analysis_file', 'upload', length=1000000000000, autodelete=True))
if db(db.auth_user.id > 0).count() == 0: if db(db.auth_user.id > 0).count() == 0:
