GitLab
Support
Community forum
Keyboard shortcuts
vidjil
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
vidjil
vidjil
aef0e801
aef0e801
Ryan Herbert
Committed by
Mikaël Salson
Nov 20, 2020
update usages of SampleSetList to use helpers
20d114a8
2
2 changed files
16 additions
7 deletions
+16
-7
server/web2py/applications/vidjil/controllers/sample_set.py
+4
-3
server/web2py/applications/vidjil/tests/unit/models/SampleSetList.py
...py/applications/vidjil/tests/unit/models/SampleSetList.py
+12
-4
aef0e801
@@ -280,13 +280,14 @@ def stats():
search
tags
parse_search
request
vars
"filter"
search
tags
parse_search
request
vars
"filter"
group_ids
get_involved_groups
group_ids
get_involved_groups
list
SampleSetList
type
tags
tags
factory
ModelFactory
helper
factory
get_instance
type
type
list
SampleSetList
helper
tags
tags
list
load_sample_information
list
list
load_anon_permissions
list
result
list
get_values
result
list
get_values
factory
ModelFactory
helper
factory
get_instance
type
type
fields
helper
get_reduced_fields
fields
helper
get_reduced_fields
##sort result
##sort result
aef0e801
@@ -16,11 +16,15 @@ class SamplesetlistModel(unittest.TestCase):
auth
login_bare
"test@vidjil.org"
"123456"
auth
login_bare
"test@vidjil.org"
"123456"
def
testInit
self
def
testInit
self
slist
SampleSetList
'patient'
factory
ModelFactory
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
self
assertTrue
len
slist
element_ids
"The sample set list was not expected to be empty"
self
assertTrue
len
slist
element_ids
def
testCreatorNames
self
def
testCreatorNames
self
slist
SampleSetList
'patient'
factory
ModelFactory
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
load_creator_names
slist
load_creator_names
values
slist
get_values
values
slist
get_values
first
values
first
values
@@ -28,7 +32,9 @@ class SamplesetlistModel(unittest.TestCase):
self
assertFalse
name
"load_creator_names failed to retrieve a username"
self
assertFalse
name
def
testPermittedGroups
self
def
testPermittedGroups
self
slist
SampleSetList
'patient'
factory
ModelFactory
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
load_permitted_groups
slist
value
slist
get_values
value
slist
get_values
groups
value
groups
groups
value
groups
@@ -38,7 +44,9 @@ class SamplesetlistModel(unittest.TestCase):
self
assertFalse
group_list
"load_permitted_groups found groups although the group_list is empty"
self
assertFalse
group_list
def
testAnonPermissions
self
def
testAnonPermissions
self
slist
SampleSetList
'patient'
factory
ModelFactory
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
slist
value
slist
get_values
value
slist
get_values
