Commit ac1d7425 authored by marc duez's avatar marc duez
url.js: filter out invalid url params
parent b6bdb365
...@@ -116,7 +116,11 @@ Url.prototype= { ...@@ -116,7 +116,11 @@ Url.prototype= {
var p = params[tmparr[0]]; var p = params[tmparr[0]];
var key = this.encoder.decode(tmparr[0]); var key = this.encoder.decode(tmparr[0]);
var val = tmparr[1]; var val = tmparr[1];
if (typeof p === "undefined") { if ((key == "") /*empty keys are due to the use of "//" in url, ignore them*/ ||
(typeof val == "undefined")) {
//do nothing
else if (typeof p === "undefined") {
params[key] = val; params[key] = val;
} else if (p.constructor === String){ } else if (p.constructor === String){
params[key] = []; params[key] = [];
...@@ -130,9 +134,8 @@ Url.prototype= { ...@@ -130,9 +134,8 @@ Url.prototype= {
var positionnal_params = url.pathname.substr(1).split('-'); var positionnal_params = url.pathname.substr(1).split('-');
var pos_param_keys = this.getPositionnalParams(); var pos_param_keys = this.getPositionnalParams();
if (positionnal_params.length > 1 && positionnal_params[0] != "index.html") if (positionnal_params.length > 1 && positionnal_params[0] != "index.html")
for (var j = 0; j < positionnal_params.length; j++) { for (var j = 0; j < positionnal_params.length; j++)
params[pos_param_keys[j]] = positionnal_params[j]; params[pos_param_keys[j]] = positionnal_params[j];
return params return params
