Commit ab49876d authored by Ryan Herbert's avatar Ryan Herbert
.gitlab-ci.yml docker tag reverse date and sha1
For easier sorting
See #3551
parent b6736c74
Pipeline #44137 passed with stage
in 7 seconds
...@@ -341,7 +341,7 @@ deploy_docker: ...@@ -341,7 +341,7 @@ deploy_docker:
script: script:
- export CUR_DATE=date +%Y-%m-%d - export CUR_DATE=date +%Y-%m-%d
- export TYPE=$CI_COMMIT_REF_NAME | awk '{ gsub(/prod-/, "") }{ print $1 }' - export TYPE=$CI_COMMIT_REF_NAME | awk '{ gsub(/prod-/, "") }{ print $1 }'
- export TAG="vidjil/$TYPE:$CI_COMMIT_SHA-$CUR_DATE" - export TAG="vidjil/$TYPE:$CUR_DATE-$CI_COMMIT_SHA"
- docker build --no-cache --build-arg git_branch=$CI_COMMIT_REF_NAME --build-arg build_env=PRODUCTION -t $TAG docker/vidjil-$TYPE - docker build --no-cache --build-arg git_branch=$CI_COMMIT_REF_NAME --build-arg build_env=PRODUCTION -t $TAG docker/vidjil-$TYPE
- docker login -u "$CI_REGISTRY_USER" -p "$CI_REGISTRY_PASSWORD" $CI_REGISTRY - docker login -u "$CI_REGISTRY_USER" -p "$CI_REGISTRY_PASSWORD" $CI_REGISTRY
- docker push $TAG - docker push $TAG
