Commit a95c2ed5 authored by Mathieu Giraud's avatar Mathieu Giraud
core/windowExtractor.{h,cpp}: **out_unsegmented_detail may be a ostream
see #4692
parent 22ad13cf
...@@ -171,7 +171,7 @@ void WindowExtractor::setUnsegmentedOutput(ostream *out) { ...@@ -171,7 +171,7 @@ void WindowExtractor::setUnsegmentedOutput(ostream *out) {
out_unsegmented = out; out_unsegmented = out;
void WindowExtractor::setUnsegmentedDetailOutput(ofstream **outs, bool unsegmented_detail_full) { void WindowExtractor::setUnsegmentedDetailOutput(ostream **outs, bool unsegmented_detail_full) {
out_unsegmented_detail = outs; out_unsegmented_detail = outs;
this->unsegmented_detail_full = unsegmented_detail_full; this->unsegmented_detail_full = unsegmented_detail_full;
...@@ -31,7 +31,7 @@ class WindowExtractor { ...@@ -31,7 +31,7 @@ class WindowExtractor {
ostream *out_segmented; ostream *out_segmented;
ostream *out_unsegmented; ostream *out_unsegmented;
ofstream **out_unsegmented_detail; ostream **out_unsegmented_detail;
bool unsegmented_detail_full; bool unsegmented_detail_full;
ostream *out_affects; ostream *out_affects;
...@@ -124,7 +124,7 @@ class WindowExtractor { ...@@ -124,7 +124,7 @@ class WindowExtractor {
* @param outs: The output streams * @param outs: The output streams
* @param unsegmented_detail_full: Whether we should output UNSEG_TOO_FEW_ZERO reads * @param unsegmented_detail_full: Whether we should output UNSEG_TOO_FEW_ZERO reads
void setUnsegmentedDetailOutput(ofstream **outs, bool unsegmented_detail_full=false); void setUnsegmentedDetailOutput(ostream **outs, bool unsegmented_detail_full=false);
* Defines the output stream where the detailed affects will be output. * Defines the output stream where the detailed affects will be output.
Supports Markdown
