Commit a4d82900 authored by Mathieu Giraud's avatar Mathieu Giraud
benchmark-releases.py: simple colored output
parent d661723b
...@@ -42,6 +42,29 @@ COMPATIBILITY = [ ...@@ -42,6 +42,29 @@ COMPATIBILITY = [
('2019.03', '-c designations', '-c segment'), ('2019.03', '-c designations', '-c segment'),
# Simple colored output
CSIm = '\033[%sm'
class ANSI:
RESET = 0
BRIGHT = 1
BLACK = 30
RED = 31
GREEN = 32
YELLOW = 33
BLUE = 34
MAGENTA = 35
CYAN = 36
WHITE = 37
def color(col, text, colorize = True):
if not colorize:
return text
return CSIm % col + text + CSIm % ANSI.RESET
def convert(cmd, release): def convert(cmd, release):
Convert a command line to be used by old vidjil-algo releases Convert a command line to be used by old vidjil-algo releases
