Commit a3adb644 authored by Mathieu Giraud's avatar Mathieu Giraud
core/fasta.cpp: defines and computes int* Sequence.seq
parent f00b60cb
...@@ -142,6 +142,7 @@ void OnlineFasta::next() { ...@@ -142,6 +142,7 @@ void OnlineFasta::next() {
current.label.erase(); current.label.erase();
current.sequence.erase(); current.sequence.erase();
current.quality.erase(); current.quality.erase();
current.seq = NULL;
if (hasNext()) { if (hasNext()) {
switch(line[0]) { switch(line[0]) {
...@@ -189,6 +190,22 @@ void OnlineFasta::next() { ...@@ -189,6 +190,22 @@ void OnlineFasta::next() {
// Sequence in uppercase // Sequence in uppercase
transform(current.sequence.begin(), current.sequence.end(), current.sequence.begin(), (int (*)(int))toupper); transform(current.sequence.begin(), current.sequence.end(), current.sequence.begin(), (int (*)(int))toupper);
// Compute seq
current.seq = new int[current.sequence.length()];
for (int i=0; i< current.sequence.length(); i++)
int B ;
switch(current.sequence[i]) {
case 'A': B = 0; break;
case 'C': B = 1; break;
case 'G': B = 2; break;
case 'T': B = 3; break;
B = 4; break;
current.seq[i] = B ;
} else } else
unexpectedEOF(); unexpectedEOF();
...@@ -12,8 +12,9 @@ typedef struct read_t ...@@ -12,8 +12,9 @@ typedef struct read_t
string label_full; string label_full;
string label; string label;
string sequence; string sequence; // Sequence: original string representation
string quality; string quality;
int* seq; // Sequence: seq representation
} Sequence; } Sequence;
typedef enum { typedef enum {
...@@ -97,6 +97,7 @@ Sequence create_sequence(string label_full, string label, string sequence, strin ...@@ -97,6 +97,7 @@ Sequence create_sequence(string label_full, string label, string sequence, strin
seq.label = label; seq.label = label;
seq.sequence = sequence; seq.sequence = sequence;
seq.quality = quality; seq.quality = quality;
// ! TODO: seq.seq, factorize with fasta.cpp
return seq; return seq;
