GitLab
What's new
7
Support
Community forum
Keyboard shortcuts
vidjil
vidjil
a327ee58
a327ee58
Ryan Herbert
sample_set.py, all.html, custom.html autocomplete search bar
See
#2621
42203d9a
3
3 changed files
11 additions
6 deletions
+11
-6
server/web2py/applications/vidjil/controllers/sample_set.py
+5
-4
server/web2py/applications/vidjil/views/sample_set/all.html
+3
-1
server/web2py/applications/vidjil/views/sample_set/custom.html
...r/web2py/applications/vidjil/views/sample_set/custom.html
+3
-1
a327ee58
@@ -170,9 +170,7 @@ def all():
request
vars
"filter"
request
vars
"filter"
search
tags
parse_search
request
vars
"filter"
search
tags
parse_search
request
vars
"filter"
group_ids
int
g
id
for
g
in
get_group_list
auth
group_ids
get_involved_groups
parent_group_ids
int
g
id
for
f
in
auth
get_user_group_parents
group_ids
group_ids
parent_group_ids
list
SampleSetList
type
page
step
tags
tags
list
SampleSetList
type
page
step
tags
tags
list
load_creator_names
list
load_creator_names
@@ -376,6 +374,8 @@ def custom():
myGroupBy
db
sequence_file
id
db
patient
id
db
run
id
db
generic
id
db
results_file
config_id
myGroupBy
db
sequence_file
id
db
patient
id
db
run
id
db
generic
id
db
results_file
config_id
group_ids
get_involved_groups
##filter
##filter
if
"filter"
not
in
request
vars
if
"filter"
not
in
request
vars
request
vars
"filter"
request
vars
"filter"
@@ -428,7 +428,8 @@ def custom():
config_id
config_id
config_id
config_id
config
config
config
config
helper
helper
helper
helper
tag_decorator
tag_decorator
tag_decorator
tag_decorator
group_ids
group_ids
def
confirm
def
confirm
if
auth
can_modify_sample_set
request
vars
"id"
if
auth
request
vars
"id"
a327ee58
@@ -8,7 +8,9 @@
@@ -8,7 +8,9 @@
<div
class=
"db_block"
<div
class=
"db_block"
<div
class=
"db_block_left"
<div
class=
"db_block_left"
search
search
<input
id=
"db_filter_input"
type=
"text"
value=
"{{=request.vars["
filter
onchange=
"db.call('sample_set/all', {'type': '{{=helper.get_type()}}', 'filter' : this.value} )"
<input
id=
"db_filter_input"
type=
"text"
value=
"{{=request.vars["
filter
onchange=
onfocus=
"new VidjilAutoComplete().setupAtWho(this);"
data-needs-atwho=
"true"
data-group-ids=
"{{=group_ids}}"
</div>
</div>
</div>
</div>
a327ee58
@@ -20,7 +20,9 @@
@@ -20,7 +20,9 @@
<input
id=
"db_filter_input"
type=
"text"
value=
"{{=request.vars["
filter
<input
id=
"db_filter_input"
type=
"text"
value=
"{{=request.vars["
filter
onchange=
"db.call('sample_set/custom', {'config_id' : '{{=request.vars["
config_id
onchange=
config_id
filter
this.value
filter
this.value
custom_list
db.getListInput
custom_result
custom_list
db.getListInput
custom_result
onfocus=
data-needs-atwho=
"true"
data-group-ids=
"{{=group_ids}}"
</div>
</div>
