GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
a15f0a91
a15f0a91
Mathieu Giraud
germline.cpp: mark_cross_germlines_as_ambiguous(), skip germlines on a same system
Such as TRD/TRD+
7c07b74e
algo/core/germline.cpp
a15f0a91
#include "germline.h"
#include <ctype.h>
void
Germline
init
string
_code
char
_shortcut
void
Germline
init
string
_code
char
_shortcut
int
_delta_min
int
_delta_max
int
_delta_min
int
_delta_max
@@ -277,6 +278,10 @@ void MultiGermline::mark_cross_germlines_as_ambiguous()
if
germline2
germline
if
germline2
germline
continue
continue
// Skip germlines on a same system, such as 'D' (TRD) and 'd' (TRD+)
if
toupper
germline2
shortcut
toupper
germline
shortcut
continue
germline
mark_as_ambiguous
germline2
germline
mark_as_ambiguous
germline2
