Commit 9f8f429e authored by Mikaël Salson's avatar Mikaël Salson
test/functional: Move a test in the correct place
This cannot be properly tested in test_segmenter_page_errors.rb as we don't have a menu there
parent 7a13de8b
Pipeline #66592 passed with stages
in 19 minutes and 21 seconds
...@@ -72,6 +72,10 @@ class TestMultilocus < BrowserTest ...@@ -72,6 +72,10 @@ class TestMultilocus < BrowserTest
assert ($b.div(:id => "left-container").present?), ">> fail : left menu did not reappear" assert ($b.div(:id => "left-container").present?), ">> fail : left menu did not reappear"
end end
def test_02_export_align_sequences
assert ( $b.menu_item_export_fasta_align(:class => 'disabledClass').exists?), ">> export align sequences is disable by default"
def test_03_rename_clone_by_clicking def test_03_rename_clone_by_clicking
clone_name = $b.clone_info('25')[:name] clone_name = $b.clone_info('25')[:name]
assert (clone_name.title == 'TRBV29*01 -1/0/-0 TRBD1*01 -2/0/-5 TRBJ2-5*01'), " >> clone name is not correct : " + clone_name.title assert (clone_name.title == 'TRBV29*01 -1/0/-0 TRBD1*01 -2/0/-5 TRBJ2-5*01'), " >> clone name is not correct : " + clone_name.title
...@@ -39,11 +39,6 @@ CGTCTT" ...@@ -39,11 +39,6 @@ CGTCTT"
assert ($b.clone_in_segmenter('0').text.include? 'CGTCTT'), "We should have sequence CGTCTT, %s instead" % $b.clone_in_segmenter('0').text assert ($b.clone_in_segmenter('0').text.include? 'CGTCTT'), "We should have sequence CGTCTT, %s instead" % $b.clone_in_segmenter('0').text
end end
def test_zz_close def test_zz_close
close_everything close_everything
end end
