Commit 9ef237e9 authored by Mathieu Giraud's avatar Mathieu Giraud Committed by Vidjil Team
patient/info.html: column sizes
parent 43b9b1a2
...@@ -37,11 +37,11 @@ ...@@ -37,11 +37,11 @@
<table class="db_table" id="table"> <table class="db_table" id="table">
<thead> <thead>
<tr><td class="column_200"> file name </td> <tr><td class="column_200"> file name </td>
<td class="column2"> sampling date </td> <td class="column_100"> sampling date </td>
<td> info </td> <td> info </td>
<td> pcr </td> <td> pcr </td>
<td class="column1"> size </td> <td> size </td>
{{if auth.has_membership('admin'):}} <td class="column_100"> uploader </td> {{pass}} {{if auth.has_membership('admin'):}} <td> uploader </td> {{pass}}
<td class="column5"> </td> <td class="column5"> </td>
...@@ -49,7 +49,7 @@ ...@@ -49,7 +49,7 @@
<td class="column_sep"></td> <td class="column_sep"></td>
<td class="column2">last processing</td> <td class="column2">last processing</td>
<td class="column2">status</td> <td class="column_100">status</td>
<td class="column5"></td> <td class="column5"></td>
<td class="column4"></td> <td class="column4"></td>
