Commit 9e87a8a3 authored by Ryan Herbert's avatar Ryan Herbert
.gitlab-ci.yml docker deploy get sha1 first 8
Only extract the first 8 characters from the commit sha1 reference
parent a7b55e16
Pipeline #44694 passed with stages
in 5 minutes and 39 seconds
...@@ -343,7 +343,8 @@ deploy_docker: ...@@ -343,7 +343,8 @@ deploy_docker:
script: script:
- export CUR_DATE=`date +%Y-%m-%d` - export CUR_DATE=`date +%Y-%m-%d`
- export TYPE=$CI_COMMIT_REF_NAME | awk '{ gsub(/prod-/, "") }{ print $1 }' - export TYPE=$CI_COMMIT_REF_NAME | awk '{ gsub(/prod-/, "") }{ print $1 }'
- export TAG="vidjil/$TYPE:$CUR_DATE-$CI_COMMIT_SHA" - export SHA=`echo $CI_COMMIT_SHA | awk '{ print substr($0, 0, 8) }'`
- export TAG="vidjil/$TYPE:$CUR_DATE-$SHA"
- docker build --no-cache --build-arg git_branch=$CI_COMMIT_REF_NAME --build-arg build_env=PRODUCTION -t $TAG docker/vidjil-$TYPE - docker build --no-cache --build-arg git_branch=$CI_COMMIT_REF_NAME --build-arg build_env=PRODUCTION -t $TAG docker/vidjil-$TYPE
- docker login -u "$CI_REGISTRY_USER" -p "$CI_REGISTRY_PASSWORD" $CI_REGISTRY - docker login -u "$CI_REGISTRY_USER" -p "$CI_REGISTRY_PASSWORD" $CI_REGISTRY
- docker push $TAG - docker push $TAG
