Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit 9df9609b authored by Mikaël Salson's avatar Mikaël Salson
Merge branch 'feature-at/update-should' into 'dev'
Feature at/update-should
See merge request !455
parents 7582cf96 a7fd2d22
Pipeline #71914 passed with stages
in 8 minutes and 16 seconds
...@@ -5,5 +5,5 @@ $ Compilation was run with -Wall ...@@ -5,5 +5,5 @@ $ Compilation was run with -Wall
>30: -Wall >30: -Wall
$ No compilation warning $ No compilation warning
f0:warning a0:warning
...@@ -5,7 +5,7 @@ $ Presence of alternative: ...@@ -5,7 +5,7 @@ $ Presence of alternative:
1: "3alt" 1: "3alt"
1: "name": "IGHJ4.02" 1: "name": "IGHJ4.02"
1: "name": "IGHJ4.01" 1: "name": "IGHJ4.01"
f1: "name": "IGHJ5.01" 1: "name": "IGHJ5.01"
1: "4alt" 1: "4alt"
1: "name": "IGHD3-22.01" 1: "name": "IGHD3-22.01"
1: "name": "IGHD3-10.02" 1: "name": "IGHD3-10.02"
...@@ -4,7 +4,7 @@ $ The KmerSegmenter segments the chimera reads on PSEUDO_MAX12 germline (-2) ...@@ -4,7 +4,7 @@ $ The KmerSegmenter segments the chimera reads on PSEUDO_MAX12 germline (-2)
f1:unexpected .* -> .* 2 f1:unexpected .* -> .* 2
$ The FineSegmenter gives the locus information (-2) $ The FineSegmenter gives the locus information (-2)
f1:Unexpected [+]IGHD/[+]TRBJ 1:Unexpected [+]IGHD/[+]TRBJ
f1:Unexpected [+]TRAV/[+]TRDD f1:Unexpected [+]TRAV/[+]TRDD
$ The FineSegmenter correclty segments the V-D and D-J sequences (-2) $ The FineSegmenter correclty segments the V-D and D-J sequences (-2)
...@@ -17,4 +17,4 @@ $ Display advanced options ...@@ -17,4 +17,4 @@ $ Display advanced options
: custom Cost : custom Cost
$ Correct number of options $ Correct number of options
B52:^ - 52:^..-
...@@ -15,4 +15,4 @@ $ Do not display advanced options ...@@ -15,4 +15,4 @@ $ Do not display advanced options
0: custom Cost 0: custom Cost
$ Correct number of regular options $ Correct number of regular options
B24:^ - 24:^..-
This diff is collapsed.
