Commit 9d98fa5a authored by Marc Duez's avatar Marc Duez
export.js : reads stat for sample report
parent 2cfc7cb8
...@@ -34,6 +34,7 @@ Report.prototype = { ...@@ -34,6 +34,7 @@ Report.prototype = {
this.w.onload = function(){ this.w.onload = function(){
self.info() self.info()
.sampleInfo(m.t) .sampleInfo(m.t)
.readsStat(m.t)
for (var i=0; i<m.system_selected.length; i++){ for (var i=0; i<m.system_selected.length; i++){
var system = m.system_selected[i] var system = m.system_selected[i]
self.addScatterplot(system, m.t) self.addScatterplot(system, m.t)
...@@ -235,7 +236,8 @@ Report.prototype = { ...@@ -235,7 +236,8 @@ Report.prototype = {
return this return this
readsStat: function() { readsStat: function(time) {
if (typeof time == "undefined") time = -1
var container = this.container('Reads statistics') var container = this.container('Reads statistics')
var reads_stats = $('<div/>', {class: 'flex'}).appendTo(container); var reads_stats = $('<div/>', {class: 'flex'}).appendTo(container);
...@@ -253,9 +255,21 @@ Report.prototype = { ...@@ -253,9 +255,21 @@ Report.prototype = {
if (time == -1){
for (var i=0; i<m.samples.order.length; i++){ for (var i=0; i<m.samples.order.length; i++){
var time = m.samples.order[i] var t = m.samples.order[i]
var box=this.readsStat2(t)
box.appendTo(reads_stats);
}else{
var box=this.readsStat2(time)
return this;
readsStat2: function (time){
var box = $('<div/>', {class: 'float-left'}) var box = $('<div/>', {class: 'float-left'})
$('<div/>', {class: 'case centered', text : m.getStrTime(time)}).appendTo(box); $('<div/>', {class: 'case centered', text : m.getStrTime(time)}).appendTo(box);
$('<div/>', {class: 'case centered', text : m.toStringThousands(m.reads.total[time])}).appendTo(box); $('<div/>', {class: 'case centered', text : m.toStringThousands(m.reads.total[time])}).appendTo(box);
...@@ -281,10 +295,7 @@ Report.prototype = { ...@@ -281,10 +295,7 @@ Report.prototype = {
pie_chart.append(p) pie_chart.append(p)
box.appendTo(reads_stats); return box
return this;
systemPie: function(time) { systemPie: function(time) {
