GitLab
Support
Community forum
Keyboard shortcuts
vidjil
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
vidjil
vidjil
989c31ca
989c31ca
Ryan Herbert
Committed by
Mikaël Salson
Nov 20, 2020
add index creation on auth_permission
56235507
4 additions
1 deletion
+4
-1
server/web2py/applications/vidjil/models/db.py
+4
-1
989c31ca
@@ -289,11 +289,14 @@ db.define_table('tag_ref',
Field
'table_name'
'string'
Field
'table_name'
'string'
Field
'record_id'
'integer'
Field
'record_id'
'integer'
# try to create an index on these un-indexed columns, if it fails, we assume they already exist
try
try
db
executesql
'CREATE INDEX table_name_index ON tag_ref (table_name);'
db
executesql
db
executesql
'CREATE INDEX record_id_index ON tag_ref (record_id);'
db
executesql
db
executesql
'CREATE INDEX name_index ON auth_permission (name);'
db
executesql
'CREATE INDEX record_id_index ON auth_permission (record_id);'
except
except
pass
pass
## after defining tables, uncomment below to enable auditing
auth
enable_record_versioning
db
auth
db
