Commit 98174d11 authored by HERBERT Ryan's avatar HERBERT Ryan
Applying more permission updating
More of the old permission system is being replaced by the new method
parent f04e5f74
...@@ -81,7 +81,7 @@ def anon_birth(patient_id, user_id): ...@@ -81,7 +81,7 @@ def anon_birth(patient_id, user_id):
age = age_years_months(birth) age = age_years_months(birth)
if auth.has_permission("anon", "patient", patient_id, user_id): if auth.get_permission("anon", "patient", patient_id, user_id):
return "%s (%s)" % (birth, age) return "%s (%s)" % (birth, age)
else: else:
return age return age
...@@ -120,12 +120,12 @@ class ConfigController(unittest.TestCase): ...@@ -120,12 +120,12 @@ class ConfigController(unittest.TestCase):
#add permission to "popipo" a config #add permission to "popipo" a config
resp = change_permission() resp = change_permission()
self.assertTrue( auth.has_permission('popipo', 'config', id_config), "fail to add a permission") self.assertTrue( auth.get_group_access('config', id_config, id_group), "fail to add a permission")
#remove it #remove it
self.assertFalse( auth.has_permission('popipo', 'config', id_config), "fail to remove a permission") self.assertFalse( auth.get_group_access('config', id_config, id_group), "fail to remove a permission")
...@@ -88,7 +88,7 @@ class GroupController(unittest.TestCase): ...@@ -88,7 +88,7 @@ class GroupController(unittest.TestCase):
request.vars["group_id"] = group_id request.vars["group_id"] = group_id
resp = remove_permission() resp = remove_permission()
auth.has_permission('admin', 'auth_group', group_id) auth.get_permission('admin', 'auth_group', group_id)
def test3ChangePermission(self): def test3ChangePermission(self):
...@@ -97,7 +97,7 @@ class GroupController(unittest.TestCase): ...@@ -97,7 +97,7 @@ class GroupController(unittest.TestCase):
def test4Rights(self): def test4Rights(self):
...@@ -54,6 +54,7 @@ class PatientController(unittest.TestCase): ...@@ -54,6 +54,7 @@ class PatientController(unittest.TestCase):
request.vars["birth"] = "2011-11-11" request.vars["birth"] = "2011-11-11"
request.vars["info"] = "test patient kZtYnOipmAzZ" request.vars["info"] = "test patient kZtYnOipmAzZ"
request.vars["id_label"] = "bob" request.vars["id_label"] = "bob"
request.vars["patient_group"] = fake_group_id
resp = add_form() resp = add_form()
print db(db.auth_permission.id>0).select() print db(db.auth_permission.id>0).select()
...@@ -105,14 +106,13 @@ class PatientController(unittest.TestCase): ...@@ -105,14 +106,13 @@ class PatientController(unittest.TestCase):
patient_id = db( db.patient.info == "test patient kZtYnOipmAzZ").select()[0].id patient_id = db( db.patient.info == "test patient kZtYnOipmAzZ").select()[0].id
request.vars["patient_id"] = patient_id request.vars["patient_id"] = patient_id
request.vars["group_id"] = 1 request.vars["group_id"] = fake_group_id
request.vars["permission"] = "popipo"
self.assertTrue(auth.has_permission('popipo', 'patient', patient_id), "fail to add permission") self.assertTrue(auth.get_group_access('patient', patient_id, fake_group_id), "fail to add permission")
self.assertFalse(auth.has_permission('popipo', 'patient', patient_id), "fail to remove permission") self.assertFalse(auth.get_group_access('patient', patient_id, fake_group_id), "fail to remove permission")
Supports Markdown
