Commit 95cef044 authored by Mikaël Salson's avatar Mikaël Salson
Merge branch 'feature-s/4240-4241-sort-configs' into 'dev'
Sort configurations, by classification then by name, and also for admins
Closes #4240 and #4241
See merge request !655
parents 7528658c 84a07ba0
Pipeline #139500 passed with stages
in 8 minutes and 16 seconds
...@@ -15,7 +15,7 @@ def index(): ...@@ -15,7 +15,7 @@ def index():
return gluon.contrib.simplejson.dumps(res, separators=(',',':')) return gluon.contrib.simplejson.dumps(res, separators=(',',':'))
query = db((auth.vidjil_accessible_query(PermissionEnum.read_config.value, db.config) | auth.vidjil_accessible_query(PermissionEnum.admin_config.value, db.config) ) ).select(orderby=~db.config.name) query = db((auth.vidjil_accessible_query(PermissionEnum.read_config.value, db.config) | auth.vidjil_accessible_query(PermissionEnum.admin_config.value, db.config) ) ).select(orderby=db.config.classification|db.config.name)
used_query = db(db.results_file.config_id > 0).select(db.results_file.config_id, distinct=True) used_query = db(db.results_file.config_id > 0).select(db.results_file.config_id, distinct=True)
used_configs = [row.config_id for row in used_query] used_configs = [row.config_id for row in used_query]
classification = db( (db.classification) ).select() classification = db( (db.classification) ).select()
...@@ -703,7 +703,7 @@ def getConfigsByClassification(): ...@@ -703,7 +703,7 @@ def getConfigsByClassification():
classification = defaultdict( lambda: {"info":"", "name":"", "configs":[]} ) classification = defaultdict( lambda: {"info":"", "name":"", "configs":[]} )
if auth.can_process_sample_set(request.vars['id']) : if auth.can_process_sample_set(request.vars['id']) :
for class_elt in db( (db.classification)).select(orderby=db.classification.id): for class_elt in db( (db.classification)).select(orderby=db.classification.id):
configs = db( (db.config.classification == class_elt.id) & (auth.vidjil_accessible_query(PermissionEnum.read.value, db.config) | auth.vidjil_accessible_query(PermissionEnum.admin.value, db.config) ) ).select(orderby=db.config.id) configs = db( (db.config.classification == class_elt.id) & (auth.vidjil_accessible_query(PermissionEnum.read.value, db.config) | auth.vidjil_accessible_query(PermissionEnum.admin.value, db.config) ) ).select(orderby=db.config.name)
if len(configs): # don't show empty optgroup if len(configs): # don't show empty optgroup
classification["%02d_%s" % (i, class_elt)]["name"] = class_elt.name classification["%02d_%s" % (i, class_elt)]["name"] = class_elt.name
classification["%02d_%s" % (i, class_elt)]["info"] = class_elt.info classification["%02d_%s" % (i, class_elt)]["info"] = class_elt.info
...@@ -711,7 +711,7 @@ def getConfigsByClassification(): ...@@ -711,7 +711,7 @@ def getConfigsByClassification():
i += 1 i += 1
classification["%02d_noclass" % i]["name"] = "–" classification["%02d_noclass" % i]["name"] = "–"
classification["%02d_noclass" % i]["info"] = "" classification["%02d_noclass" % i]["info"] = ""
classification["%02d_noclass" % i]["configs"] = db( (db.config.classification == None) & (auth.vidjil_accessible_query(PermissionEnum.read.value, db.config) | auth.vidjil_accessible_query(PermissionEnum.admin.value, db.config) ) ).select(orderby=db.config.id) classification["%02d_noclass" % i]["configs"] = db( (db.config.classification == None) & (auth.vidjil_accessible_query(PermissionEnum.read.value, db.config) | auth.vidjil_accessible_query(PermissionEnum.admin.value, db.config) ) ).select(orderby=db.config.name)
return classification return classification
def getStatHeaders(): def getStatHeaders():
