Commit 91adbc24 authored by Mathieu Giraud's avatar Mathieu Giraud
split-from-imgt.py: when gene_id is found, extract from chromosome rather than gene
Closes #3009 ? To be verified.
parent eca46b8c
...@@ -8,7 +8,7 @@ import urllib ...@@ -8,7 +8,7 @@ import urllib
from collections import defaultdict, OrderedDict from collections import defaultdict, OrderedDict
import re import re
from ncbi import * import ncbi
IMGT_LICENSE = ''' IMGT_LICENSE = '''
# To use the IMGT germline databases (IMGT/GENE-DB), you have to agree to IMGT license: # To use the IMGT germline databases (IMGT/GENE-DB), you have to agree to IMGT license:
...@@ -104,14 +104,22 @@ def retrieve_genes(f, genes, tag, additional_length, gene_list): ...@@ -104,14 +104,22 @@ def retrieve_genes(f, genes, tag, additional_length, gene_list):
for gene in genes: for gene in genes:
for coord in genes[gene]: for coord in genes[gene]:
gene_id = gene_list.get_gene_id_from_imgt_name(coord['species'], coord['imgt_name']) gene_id = gene_list.get_gene_id_from_imgt_name(coord['species'], coord['imgt_name'])
print(coord, gene_id)
if gene_id:
# gene_id is found, extract from chromosome
(target, start, end) = ncbi.get_gene_positions(gene_id)
print(coord, gene_id, target, start, end)
else:
# extract from gene
target = gene
start = coord['from'] start = coord['from']
end = coord['to'] end = coord['to']
if additional_length > 0: if additional_length > 0:
end += additional_length end += additional_length
elif additional_length < 0: elif additional_length < 0:
start = max(1, start + additional_length) start = max(1, start + additional_length)
gene_data = get_gene_sequence(gene, coord['imgt_data'] + tag, start, end) gene_data = ncbi.get_gene_sequence(target, coord['imgt_data'] + tag, start, end)
if coord['imgt_data'].split('|')[-1] == FEATURE_J_REGION: if coord['imgt_data'].split('|')[-1] == FEATURE_J_REGION:
gene_lines = gene_data.split('\n') gene_lines = gene_data.split('\n')
gene_lines[1] = gap_j(gene_lines[1].lower()) gene_lines[1] = gap_j(gene_lines[1].lower())
