Commit 90b8bb4e authored by Mikaël Salson's avatar Mikaël Salson
vidjil.cpp: Output in .vidjil even when FineSegmentation is not computed
Previously the sequence, coverages, affects and e-values were not output if
the FineSegmentation was not computed. The code is now reordered to ensure
that this information is output in the .vidjil.
parent 3077fe7e
...@@ -1315,12 +1315,29 @@ int main (int argc, char **argv) ...@@ -1315,12 +1315,29 @@ int main (int argc, char **argv)
representative.label = clone_id + "--" + representative.label; representative.label = clone_id + "--" + representative.label;
//$$ If max_clones is reached, we stop here but still outputs the representative // Re-launch also a KmerMultiSegmenter, for control purposes (affectations, evalue)
KmerMultiSegmenter kmseg(representative, multigermline, 0, expected_value, nb_reads_for_evalue);
KmerSegmenter *kseg = kmseg.the_kseg ;
if (verbose)
cout << "KmerSegmenter: " << kseg->getInfoLine() << endl;
json json_clone;
json_clone["sequence"] = representative.sequence;
json_clone["_coverage"] = { repComp.getCoverage() };
json_clone["_average_read_length"] = { windowsStorage->getAverageLength(it->first) };
json_clone["_coverage_info"] = {repComp.getCoverageInfo()};
//From KmerMultiSegmenter
json_clone["seg"] = kseg->toJson();
if ((max_clones >= 0) && (num_clone >= max_clones + 1)) if ((max_clones >= 0) && (num_clone >= max_clones + 1))
cout << representative << endl ; cout << representative << endl ;
out_clones << representative << endl ; out_clones << representative << endl ;
json_data_segment[it->first] = json_clone;
continue; continue;
...@@ -1341,29 +1358,14 @@ int main (int argc, char **argv) ...@@ -1341,29 +1358,14 @@ int main (int argc, char **argv)
out_clone << seg << endl ; out_clone << seg << endl ;
out_clones << seg << endl ; out_clones << seg << endl ;
KmerMultiSegmenter kmseg(seg.getSequence(), multigermline, 0, expected_value, nb_reads_for_evalue);
if (verbose)
json json_clone;
// From FineSegmenter // From FineSegmenter
json_clone["sequence"] = seg.getSequence().sequence;
json_clone["name"] = seg.code; json_clone["name"] = seg.code;
json_clone["seg"] = seg.toJson(); json json_fseg = seg.toJson();
for (json::iterator it = json_fseg.begin(); it != json_fseg.end(); ++it) {
json json_kseg = kseg->toJson();
for (json::iterator it = json_kseg.begin(); it != json_kseg.end(); ++it) {
json_clone["seg"][it.key()] = it.value(); json_clone["seg"][it.key()] = it.value();
json_data_segment[it->first] = json_clone; json_data_segment[it->first] = json_clone;
if (seg.isSegmented()) if (seg.isSegmented())
