Commit 90a27598 authored by Mikaël Salson's avatar Mikaël Salson
segment: Optimise probability computation.
Avoid using pow in the loop. Call it once and then multiply or divide.
parent a51084cd
...@@ -358,8 +358,12 @@ double KmerSegmenter::getProbabilityAtLeastOrAbove(int at_least) const { ...@@ -358,8 +358,12 @@ double KmerSegmenter::getProbabilityAtLeastOrAbove(int at_least) const {
float index_load = getKmerAffectAnalyser()->getIndex().getIndexLoad() ; float index_load = getKmerAffectAnalyser()->getIndex().getIndexLoad() ;
double proba = 0; double proba = 0;
double probability_having_system = pow(index_load, at_least);
double probability_not_having_system = pow(1 - index_load, n - at_least);
for (int i=at_least; i<n; i++) { for (int i=at_least; i<n; i++) {
proba += nChoosek(n, i) * pow(index_load, i) * pow(1-index_load, n-i); proba += nChoosek(n, i) * probability_having_system * probability_not_having_system;
probability_having_system *= index_load;
probability_not_having_system /= index_load;
return proba; return proba;
Supports Markdown
