Commit 8ebed2b1 authored by Marc Duez's avatar Marc Duez
server : update due to fuse.py change
parent 2ab5e312
...@@ -267,7 +267,7 @@ def result(): ...@@ -267,7 +267,7 @@ def result():
files += " applications/Vidjil_test/uploads/"+row.data_file.data_file files += " applications/Vidjil_test/uploads/"+row.data_file.data_file
if error == "" : if error == "" :
cmd = "python ../fuse.py "+output_file+" 50 "+files cmd = "python ../fuse.py -o "+output_file+" -t 100 "+files
p = Popen(cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=True) p = Popen(cmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=True)
time.sleep(1) time.sleep(1)
