Commit 8e070fb3 authored by Ryan Herbert's avatar Ryan Herbert
task.py compute extra check for keys and NoneType
See #3626
parent c9cf9aa9
Pipeline #49389 passed with stages
in 6 minutes and 45 seconds
...@@ -102,16 +102,18 @@ def compute_extra(id_file, id_config, min_threshold): ...@@ -102,16 +102,18 @@ def compute_extra(id_file, id_config, min_threshold):
try: try:
d = json.load(rf) d = json.load(rf)
loci_min = {} loci_min = {}
loci_totals = d['reads']['germline'] if 'reads' in d and 'germline' in d['reads']:
for locus in loci_totals: loci_totals = d['reads']['germline']
if locus not in result: for locus in loci_totals:
result[locus] = [0] if locus not in result:
loci_min[locus] = loci_totals[locus][0] * (min_threshold/100.0) result[locus] = [0]
for clone in d["clones"]:
germline = clone['germline'] if 'clones' in d and d['clones'] is not None:
if clone['reads'][0] >= loci_min[germline]: for clone in d["clones"]:
result[germline][0] += 1 germline = clone['germline']
except ValueError as e: except ValueError as e:
print('invalid_json') print('invalid_json')
return "FAIL" return "FAIL"
