Commit 8d64f661 authored by HERBERT Ryan's avatar HERBERT Ryan
controllers/sample_set.py failsafe for page
parent 1ee9795a
...@@ -176,6 +176,7 @@ def all(): ...@@ -176,6 +176,7 @@ def all():
# failsafe if filtered display all results # failsafe if filtered display all results
step = len(list) if step is None else step step = len(list) if step is None else step
page = 0 if page is None else page
factory = ModelFactory() factory = ModelFactory()
helper = factory.get_instance(type=type) helper = factory.get_instance(type=type)
